      09-02-2020, 10:29 PM   #1
ZBoy
Drives: BMW M3 Z4
What Headlight LED Upgrades exist for e85? Z4
Anyone have success and found a manufacturer and product to update/upgrade headlights to LED?
ZBoy
      09-24-2020, 08:00 AM   #2
rsutoratosu
Drives: Z4 3.0i
Nope.. been looking for a while.. prob too old to make money off so no ones done it.. unless its a DIY
-Roranji
      09-24-2020, 10:35 AM   #3
rsutoratosu
Drives: Z4 3.0i
Also they have these listed, thats an insane price and probably beam pattern isn't DOT or even tested. not worth the trouble to get any aftermarket led, especially from ali express. I wouldn't even list these as viable option
https://www.aliexpress.com/item/32824253860.html
-Roranji
      09-27-2020, 11:18 PM   #4
pungo
pungo's Avatar
Gotta love the "LED angle eyes drl" I guess the shine to the side
BTW, they're HID, not LED beams
      09-27-2020, 11:19 PM   #5
pungo
pungo's Avatar
dup
      10-01-2020, 09:04 AM   #6
rsutoratosu
Drives: Z4 3.0i
Yes because no one really makes them.. car is too old, LED was not widely used back then in headlights... its not till recently LED became popular.
Thats why you have retrofit forums, its going to be DIY or cheap aftermarket hacks
-Roranji
      10-08-2020, 06:21 PM   #7
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
For over a year I've been running DDM Tuning Saber LED (H7, 50W). They have been an improvement over the aftermarket HIDs I had installed before.
The LEDs are a drop-in solution (replacing the stock halogen bulbs) and required minor fitting of the bulb holders. It was a bit of a squeeze but everything fit and I haven't had any issues with them at all.
I'm not sure if it would be the same process with a stock bi-xenon setup. Then again, if I had the stock bi-xenon setup I probably wouldn't convert to LED.
2008 Z4 3.0si Coupe
      10-09-2020, 10:32 AM   #8
bwright657
bwright657's Avatar
258
Drives: 08 Z4 M Coupe
You can get a pretty substantial upgrade with retrofitting LEDs for the running lights and new bulbs. Pungo did my LED upgrade and they match perfectly with Osram Xenarc Cool Blue bulbs. The actual light is closer to white than blue and they're much better at night than the stock bulbs.
      10-09-2020, 04:21 PM   #9
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
Do you have links to what you used?
      10-10-2020, 02:30 PM   #10
bwright657
bwright657's Avatar
258
These are the bulbs I used:
https://www.amazon.com/gp/product/B0771VZ353/
For the rest, you'd have to see if Pungo (he replied earlier in this thread) will reveal his secrets. Or send him your lights, turnaround is pretty quick.
