      08-25-2020, 09:20 AM   #1
wyshyvanuk
Drives: 2008 Z4 MR
ECU Terminal 15
This is kind of a modification of a previous post about ECU wiring. In an effort to install a relay to control an add on electric water pump, I apparently need to tap into "terminal 15" in the ECU. Does anyone know the location of this terminal 15? My inexperience with wiring issues has me way out of my depth here. Thanks for any help!!
      08-25-2020, 11:07 AM   #2
Clearancediver
Drives: 2004 Z4
Google ... terminal 15 bmw.... it's power supply
Sent from my smart phone...
      08-25-2020, 04:55 PM   #3
wyshyvanuk
Drives: 2008 Z4 MR
Yeah, I understand what it is, but I'm trying to identify where one is located in the ECU.
Thanks.
      09-21-2020, 10:14 PM   #4
t3ddftw
Drives: E46 M3
Thanks.
Terminal 15 is easy to spot as it is a purple wire with a white stripe to it. Here's the wiring diagram for the Z4M DME: https://www.newtis.info/tisv2/a/en/e....2-cou/Z8TkuuA
-Ted
      09-25-2020, 01:12 PM   #5
wyshyvanuk
Drives: 2008 Z4 MR
Thank you, sir!!!
      10-23-2020, 01:22 AM   #6
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
t3ddftw, how did you know it's a purple wire with white stripe? (noob here, thanks for your patience )
      04-19-2021, 07:44 PM   #7
t3ddftw
Drives: E46 M3
Actually, I guess I was wrong. It's green and purple. Generally, BMW sticks to a specific color code for the wire throughout the car, and for most E-series cars, Terminal 15 is White and Purple.
WDS tells you the wire color: https://bmwteka.com/wds/en/e85/2f1d8b27
You can see the 15<9 (Pin 1) is GN/VI which is the German abbreviation for Grun and Violet.
Thanks!
-Ted
