      07-21-2019, 08:56 PM   #1
3002 tii
3002 tii's Avatar
2286
Air Dam Solution for Front Splitter
For those running front splitters like APR, do you have an air dam to fill that center gap (sorta like the M stache)?
Follow for latest mods
      07-22-2019, 05:41 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Pretty sure Ian or Ron had a solution to this, think it was a piece of lexan that fit in-between the splitter and the bumper, about and inch thick.
Powered by
      08-02-2019, 09:57 AM   #3
F360C
Drives: E86 S54
My brother and I both bought the ones made by Ian back in the day. His cracked so I ended up making a new one from some flexible house trim you can source at home depot. Its easy to cut, paintable and very flexible so it easy to install.
I also ended up making up both lips to go on the leading edge of the APR splitter from the same stuff. Looks a bunch better then it being raw and adds a bit of meat to the splitter. I'll take a pic of what I did tonight.
07 Z4 M Coupe AW/IR
3002 tii2285.50
      09-02-2023, 09:30 PM   #4
3002 tii
3002 tii's Avatar
2286
4 year bump, finally going to mount my splitter that’s been sitting in the garage all this time. Anyone else come up with an air dam solution?
      09-03-2023, 06:17 AM   #5
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
I've been fooling around with idea of using some HD 1/4" rubber conveyor belt I picked years ago, very stiff but still flexible, the wind won't deflect it but a solid object would.
I'm thinking of using it as a vertical dam, if the bottom contacts the road surface it will just wear a bit off the lower edge, it's flat black.
2008 E86 M coupe
      09-03-2023, 08:39 AM   #6
3002 tii
3002 tii's Avatar
2286
I was thinking of using one of those ez lip or all fit lip kits. Pro being it’s easy to install/trim; con being it’s so cheap and flimsy.
