      04-26-2021, 09:05 AM   #1
Dynamics99
Drives: 2011 E92 & E90 335i 6MT MSport
No power from driver window after swapping door
Hi,
I do not get any power from my driver window after swapping the door. The window regulator motor in the new door is 2 pin. The old door is 6 pin. Is there a solution to this? I got the old window regulator motor out (6 pin) but the new one I cannot manually pull up the window to get the 3rd torx screw out. Can I control the window from INPA?
Update:
Use a 12v source(Noco genius has a 12v supply mode) and two wires and wired it up to the motor in reverse polarity to make the window go up to give space for the torx bolts. Took out the motor and swapped in the old one along with the door harness. Resolved my issue.
wdb4732.00
Tags
window regulator stuck down
