      11-23-2017, 08:01 AM   #45
Punisher3.0si
Drives: 2007 E86 manual
Flat spots don't happen on Radial tires from sitting. That's a bias ply issue. It amazes me this still gets brought up as a problem.
      11-23-2017, 09:12 AM   #46
3798j
3798j's Avatar
11412
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Gotta disagree. While flat spotting is not as much an issue with low aspect ratio tires, many 65, 70, and 80 series radials certainly are prone to storage flat spots.
      11-24-2017, 02:01 AM   #47
StickMon
StickMon's Avatar
Drives: 2006 MR
^WHS
I had 60s on my MR2 that I would store when I was back in Chicago and it took a week of hard driving to get them back to being round in the spring.
Subsequent years of storage I put it up on stands and took the wheels off.
      12-11-2017, 07:44 AM   #48
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
I lay down roofing tar paper on the floor to keep the moisture down in my garage, as a roll of that paper is cheap.
Pull the battery and it comes into the house.
Car sits on crappy tires on the original 18" wheels, so not caring about that.
      12-11-2017, 09:43 AM   #49
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Daily driver....even in the rainy Pacific Northwest.
Racerbruce
      12-12-2017, 09:03 PM   #50
bmwclubracer
Drives: Z4
My condolences guys...here in Atlanta I'll drop the top, heated seats, direct the heat towards my hands and drive around in 40 degree weather.
      12-12-2017, 09:05 PM   #51
bmwclubracer
Drives: Z4
I've heard it's an old wives tale that cold kills batteries...I understand it's the heat that kills them. The heat wears 'em out and then they fail in the winter.
      12-13-2017, 06:28 AM   #52
wdb
dances with roads
wdb's Avatar
4732
Don't forget the snowshoes...
      12-27-2017, 02:31 PM   #53
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
-6 degrees and salty as an overtaxed Libertarian here in Wisconsin. Fortunately my Toyota is taking all the salt for the team.
      12-27-2017, 11:41 PM   #54
Kenneth Carroll
Drives: 2008 Z4M
I'm with Clubracer here in Atlanta. It gets cold, but not really cold enough to store the car. I just keep it in the garage with a tender if I am not going to drive it for a couple of weeks.
      12-28-2017, 10:58 AM   #55
rplamb
Drives: 2018 X3 3.0i M sport
Here in NH we are cold and snowy. Right now it's 4 degrees with a wind chill of 9 below. Car is in a climate controlled 100K sq ft facility with 500 other cars. All have tenders and pads under the tires. Car's happy, I'm happy. Pull it out in April.
2018 X3 3.0i M sport - mine
2014 428i- conv - Hers
      12-29-2017, 09:18 AM   #56
wdb
dances with roads
wdb's Avatar
4732
Are you fabulously wealthy, or is that a shared space?
      12-31-2017, 06:49 AM   #57
Kenneth Carroll
Drives: 2008 Z4M
If he is fabulously wealthy, I am searching for a parent!
      12-31-2017, 03:34 PM   #58
Huz-Z
Huz-Z's Avatar
a couple of pics for the topic:
if you look closely you may be able to see the battery tender behind the driver mirror with the status light glowing green while the car waits patiently for spring. Until then, the red Honda blower will be seeing use (and I hope not too much).
Huz-Z
wdb4732.00
      12-31-2017, 04:29 PM   #59
wdb
dances with roads
wdb's Avatar
4732
You could almost submit that picture for the annual Z4 calendar. It would be a good winter shot!
      01-02-2018, 02:48 AM   #60
mainsoda
mainsoda's Avatar
Looks like a wonderful garage. I love the Stig poster.
      01-02-2018, 05:09 AM   #61
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
No worries. It's 4 deg. here in central Virginia today. I'll just walk outside, startup the si Coupe crank up the heated sport seats and enjoy the 24,000 ft-lb/deg. drive to work.
      01-06-2018, 08:36 PM   #62
Z4dugh
Drives: 2008 E86 Z4 MC
Winter hibernation
Fresh oil, full tank, CTek & cover
      02-04-2018, 10:40 AM   #63
Slalom
Slalom's Avatar
Drives: 04 Z4, 18 X3 M40i
2004 Z4  [0.00]
2018 BMW X3 M40i  [10.00]
My routine for the last 13 winters has been oil change, top up with ethanol free gas, stabilizer, breathable cover, climate controlled storage with lots of rodent protection, maintainer on the battery, detail before going away, boost air pressure in tires, fabric softener sheets in cabin and trunk. Goes away in November out in April.
      02-04-2018, 08:25 PM   #64
mainsoda
mainsoda's Avatar
I miss my Z, but I'm still having fun.
https://youtu.be/SIzzN4GOesY
