View Poll Results: What wheel diameter would you choose for a track/autox/weekend setup? | |||
17" | 6 | 8.96% | |
18" | 40 | 59.70% | |
19" | 21 | 31.34% | |
Voters: 67. You may not vote on this poll |
07-06-2011, 11:55 PM | #1 |
Rep 494
Poll: Vote for your preferred wheel size
Hello all,
I'm trying to decide what size wheels I should go with for a track/autox/weekend set up and would like the forum's input. Initially I thought I'd run a 19" set up to get a lower profile tire, but the idea of a lighter wheel, cheaper tire, and larger tire selection is tempting. I'm going to try and post a poll for everyone to vote, but would also appreciate it if you could leave comments about why or why not you would go with a particular size. In the future I'll tabulate the pros and cons for each wheel size and post them at the front of this thread. (I realize that width and offset also plays significantly in the selection of the final set up, but for this post I'm more concerned about diameter.)
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| Last edited by jdl1pt; 07-07-2011 at 10:50 AM.. |
07-07-2011, 12:42 AM | #3 |
Rep 10,309
Drives: A///MERICAN!!!
Didn't read before I voted...for autox/track 17s
07-07-2011, 01:01 AM | #4 |
Rep 509
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
07-07-2011, 07:50 AM | #6 |
Rep 409
what 17's will fit over the front brakes on an ///m? surely it must be SUPER close to hitting the caliper...?
07-07-2011, 08:03 AM | #7 |
Rep 5,329
a nice lightweight 19" for me...... looks and performance :-) My BBK has Huge front rotors....
07-07-2011, 11:44 AM | #8 |
704
18s for the following reasons:
07-07-2011, 01:42 PM | #9 |
Rep 494
Ron, thanks for your feed back. Interesting point about heat disipation with the 17.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
07-07-2011, 03:06 PM | #10 | |
Rep 10,309
Edit: pic with the OZs Last edited by BTM; 07-07-2011 at 03:12 PM.. |
07-07-2011, 03:17 PM | #11 | |
Rep 10,309
07-07-2011, 03:38 PM | #12 |
Rep 409
if you can pick up some 17's under 16 lbs ea you'd be set (as far as rotational intertia goes).
the only thing to consider then would be how much deflection in the sidewall of the tires is tolerable. you could even reduce the overall diameter of the tire to (theoretically) have better acceleration. it'll mess with your cluster a bit, but since it's your track car... where's HACK at? he knows all about this stuff!
07-07-2011, 11:06 PM | #13 |
Rep 494
Where is Hack, I would appreciate his input.
07-09-2011, 12:01 PM | #15 |
M52, M62TU, S50US, S54, S65
75
Rep 569
If there's no BBK involved, 17" is the way to go. The wheels are lighter, the tires are lighter and MUCH cheaper. IMHO it's the best choice for track.
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT 1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT 2002 E39 540i Protection |
07-09-2011, 02:52 PM | #16 |
The Photographer
76
Rep 628
I would get 19s if i ever drove it on the street. 18s if i didnt (lots of options).
I would love a set of 18x12 ccw classics though, i'd rock those anywhere.
John Batte Photography / Flickr / Facebook 2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob |
07-13-2011, 03:45 PM | #17 |
1821
Rep 5,337
For performance purposes, the equation is simple.
Put the grippiest tires with the lightest wheel and tire combination and widest possible setup on the car that will clear the brakes. However in real life it's NEVER that simple. To put it another way. If you can not change the grip of the tire (meaning you're using a specific range of compounds) significantly, you will want to put the lightest rims on for best performance. If you can get a set of 20" rims that weigh less than a set of 15" rims? Get the 20" rims because it's lighter. Unfortunately, if you can make a 20" rim lighter than a 15" rim, you can take that same material and technology and make that same 20" rim design in a 15" rim and it'll again be significantly lighter than the 20" rim. HOWEVER. That 15" rim will not clear the brake rotors and calipers. No way. Typical rule of thumb is, add 4" to the rotor diameter to get the smallest wheels that will fit, and on the MZ4, that means the smallest rim that will fit is an 18" (13.5" + 4" = 17.5") rim. There are certain 17" spoke/barrel design that will barely clear the front brakes. So the wheel diameter part of the equation? The lightest 18" available. Unless there are some 17" that will clear the brakes that's even lighter than the lightest 18". However, again, once you start throwing other variables in then you'll need to re-evaluate. For example, if that 17" rim does not come in a specific width available for the widest possible compound, i.e. you can't fit 275's in the rear because that 17" rim only comes in 7.5" width? Or if the sticky tires you're getting for free only comes in the 17" size? Or if the class you're running in only permits OEM size rim/tire combo? Those are all factors that will determine what is the "optimum" size wheel and tires you need to use. For example, I'm not too keen on spending a couple of grand on a set of light weight wheels, but I am keen on running Nitto NT-01 R-Comps at 245F/275R, since I get the rears for free as scrubs from a friend. Luckily at 245 front and 275 rear, they're just barely narrow enough to run on the factory wheel per the tire manufacturer's recommendations. So that's what I use, the factory rim, for track use. Now, if I start working again soon before my severance pay runs out, I might blow the rest of my severance on a set of light weight forged rims, 18"x8.5" front and 18"x9.5" rear to make the tires run on its nominal width rim, or I might just blow that on a set of light weight rims for the WRX so I can run the Hoosiers I got for dirt cheap on it.
07-13-2011, 10:03 PM | #18 | |
Rep 494
07-13-2011, 10:30 PM | #19 |
Rep 1,135
i say if i only had one set of wheels, 18s. if i could afford a "track" set of wheels, 19's for the street (i suppose) and 18's or 17's, depending on how much you want to spend, sizes and fitment, etc.
good luck John ! |
