      10-01-2021, 07:16 PM   #1
soundofspeed
Drives: E36 M3, E86 Z4M, E90 M3
S54 rough idling - many fault codes
happened from one day to the next.
Was driving perfectly, wanted to start 5 days later. Rough start, lots of misfiring. Didn't recognize the secondary air pump.
Lotīs of error codes popped up:
2A00 - secondary air system
2D06 - DME: mass air system
2F65 - DME: brake booster system check
all the misfiring for the cylinder
it went better after the car got warm.
Cleard all the codaes, after warmup less codes showed up:
2FDA - DME: crankcase ventilation, system check
and, after driving for a while,
when disconnecting the HFM and the crankcase ventilation valve on top of th engine, the corrospondending electric error codes showed up.
Air fuel ratio adjustment is working. Car has power when driving, don't feel a difference.
With the autel system I was able to turn on the secondary air pump, so connections the the air pump seem to work.
Interesting observation:
When opening the oil filler cap, nothing changes, also AFR adaption doesn't change.
When driving, also mass air flow in kg/h doesn't change, stays constant at 1,1kg/h.
Have to check if secondary air pump starts when engine is cold.
Thanks for all ideas.
      10-02-2021, 01:48 PM   #2
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Possibly the MAF?
Mine recently died on the track car. At first the symptoms were random and infrequent. Rough idle was definitely one of the symptoms.
Mine didn't throw any codes, but a lot of systems have been eliminated from the car and the ECU.
      10-04-2021, 08:46 AM   #3
drocket77
Drives: 2004 BMW Z4
I would check MAF first, than O2 sensors. My car did this, as the previous owner had all the O2 sensors before the cat. I "kinda fixed it" with a spark anti fouler for the "rear" O2's. It never threw a code for the O2's, and would have random misfires with the exception of 1 of the cylinders(think it was #1). But now I still get a misfire every now and than, but only when I am at a lower speed with a low constant RPM. I plan on getting this fixed, but do not have an inspection for 1.5 more years. When I get time and more welding skill I will attempt to fix it.
      10-04-2021, 11:28 AM   #4
wdb
dances with roads
wdb's Avatar
4732
Sounds like a vacuum leak.
      10-09-2021, 05:12 PM   #5
soundofspeed
thank you all for the ideas.
Checked the MAF again, in the MAF only gives a constant value.
Drove to a friend with a Z4M, put in his MAF and it showed values.
Will order a new MAF now.
      10-16-2021, 07:56 PM   #6
soundofspeed
put in a new MAF.
Works without problems now.
racerbruce3853.50
