      04-20-2011, 11:37 AM   #1
cmichaelo
cmichaelo's Avatar
46
Drives: '10 E92 M3, '22 Toyota Rav4
Z4M crossover pipe material
I'm planning some mods to the Z4 M crossover pipe. Want to take out the resonator and replace with some better flowing pipe. So I need to know what material to get the tubing in.
Anyone know what material the Z4 M crossover pipe is made of?
Aluminum ?
Stainless 304 ?
Stainless 409 ?
All I know for sure is that it's not carbon steel...
-M
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale:
E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims
Z4MC: KW V3 coilovers (rears)
      04-20-2011, 11:55 AM   #2
O-cha
O-cha's Avatar
218
Drives: Mcoupe
its stainless, you're wasting your money. Resonators do not restrict flow at all.
      04-20-2011, 11:55 AM   #3
cmark8
M52, M62TU, S50US, S54, S65
cmark8's Avatar
75
Drives: E90 M3 6MT, E36 Touring MT
My SS X-Pipe is made out of Stainless 304.
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT
1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT
2002 E39 540i Protection
      04-20-2011, 12:25 PM   #4
Drives: M2 Comp
Rouge Eng. has an X-pipe that replaces the OE section
      04-23-2011, 01:15 PM   #5
cmichaelo
cmichaelo's Avatar
46
Thanks for your replies.
If it's stainless, how do I tell the difference whether it 304 and 409?
Btw, I'm doing this mod predominantly because I like welding and because I've had success in the past putting an entire exhaust system together.
Obviously my goal is to improve sound and flow at the same time.
I have not cut the resonator out yet. But I suspect it does in fact restrict flow as follows. If you look closely at the input pipes to the resonator, you will see that the pipes have been crimped, or crushed, on the outer sides. It looks like a 3" x 1.5" long 1/2" recessed indentation. My guess is that this was done to cause turbulence of the gases in the resonator to make the resonator more effective. Turbulence, however, is not good for flow.
By removing this turbulence, the flow should improve. Secondly, by removing the resonator, the exhaust will become a little louder and probably, flow is improved a tiny bit more because it looks, from the outside, that the bend inside the resonator is tight.
Aftermarket crossover pipes are 2 1/4" all the way to the muffler. This, I believe, is too big for optimal flow at this portion of the exhaust. I think the optimal design is somewhere in the middle between the stock and the aftermarket crossover pipes. I feel that 2" piping, after the X-pipe section, is optimal for HP up to 400HP and that is effectively what the stock crossover pipe size is immediately after the X-pipe section.
See, gases are not that hot after the X-pipe section and therefore can benefit from a smaller pipe size to keep them moving fast and thus slightly aid the scavenging effect. After all, the secondary cat section is also made of 2 1/4" pipes, and here gases are much hotter. Thus, pipe size further down should shrink to make for a wholesome integrated exhaust system, and which BMW actually did. Even their mufflers are made of 2" piping. They just don't flow that well.
I also plan to wrap the entire crossover pipe in thermal wrap to keep the gases as hot and fast as possible.
-M
For sale:
      04-23-2011, 04:10 PM   #6
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
It's 409
      04-24-2011, 10:44 AM   #7
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
dont wrap just jet hot coat it
      04-28-2011, 09:56 AM   #8
cmichaelo
cmichaelo's Avatar
46
Dio, Thanks. Now I can go get the proper welding wire.
Villa, I had not considered that. Will look into it.
For sale:
      04-28-2011, 10:01 AM   #9
O-cha
O-cha's Avatar
218
Drives: Mcoupe
-M
      04-28-2011, 11:54 AM   #10
cmichaelo
cmichaelo's Avatar
46
I hear sighing helps you to relax and vent feelings. I could sure use some of that. Thanks Cha!
For sale:
      04-28-2011, 03:32 PM   #11
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Take good care of my X-pipe. Maybe if you get good results I will buy it back from you !
The Raspinator
