      09-17-2008, 03:22 PM   #1
Incompatible
Drives: 07 AW Z4C 3.0Si
TPMS Valve Stem Caps
I've got an 07 with the TPMS units in the valve stems. I've heard that it is necessary to use the oem caps or the sending units will not function properly. Fact or Fiction? I'm at work so I can't pull a cap and check. TIA
      09-18-2008, 02:13 PM   #2
jmillet
jmillet's Avatar
63
Thumbs down FICTION
FICTION!! The OE cap is made of plastic rather than metal to address corrosion issues of earlier metal caps.
Also the BMW Corporate lawyers wanted to warn you that there is a tire pressure monitor inside and you must reset your TPM. This novella will not fit on the face of a metal cap .
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      09-18-2008, 02:19 PM   #3
Hawkeye
Hawkeye's Avatar
No_Country
2070
False because of what was said above. If you get metal caps they easily corrode and become uber hard to get off. Any plastic caps will work though
      09-18-2008, 08:24 PM   #4
Incompatible
Thanks all for the info. Now I'm looking for some silver color plastic caps.
