      06-10-2011, 11:03 PM   #1
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Aftermarket Flex disc/Guibo from Revshift....preliminary review...
So after that Bear Mountain Run on Memorial day weekend, I realized that after all the mods The new power on 57k old Flex Disc (aka: guibo) did not go over smoothly.....it gave out, so at low speed accelerations i get the vibrations.....badly.
I went searching....found something that replaces the oem F/D on the Drive shaft......I ordered it.
I will be installing it in the morning....
It looks serious...
I made a review of some sort....
      06-10-2011, 11:10 PM   #2
Z4-VILLA
Afghanistan
111
And as a precaution i also got the driveshaft support bushing mount thingy....
      06-11-2011, 09:34 AM   #3
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Normally, this disc would add some NVH, but I see you're already running urethane motor mounts and trans mounts, so this will be a sweet addition.
      06-11-2011, 10:46 AM   #4
Z4-VILLA
Afghanistan
111
the install was perfect......NVH doesnt matter when youre running RPI and headers....I love the design that they put into this......will post pics of the whole thing shortly....
      06-11-2011, 11:06 AM   #5
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
thanks for the info! something all of us will be looking into in the near future
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      06-11-2011, 12:07 PM   #6
Z4-VILLA
Afghanistan
111
ok here all the pics in chrono order.....I hope this raises guibo awareness and promotes the awesomeness that is Revshift.....lol.
F%&k Oem Bushings and Oem Rubber.....
      06-11-2011, 01:03 PM   #7
Z4-VILLA
Afghanistan
111
no explanation needed here the pics say it all....
      06-11-2011, 01:18 PM   #8
Z4-VILLA
Afghanistan
111
well it took about as long to upload the pics as it did to drop the exhaust to install the parts in the pics themselves....
      06-12-2011, 12:20 AM   #9
VitaminT
Drives: 2006 M Roadster
I have heard about the guibo cracking on M3s but after buying one a while back the OEM piece seems pretty serious. It makes me wonder if you hanger bearing failure may have caused the guibo to crack. While the changes you made it seems would prevent any type of failures I have to wonder what it might do to other things in the case of a failure.
      06-12-2011, 02:06 AM   #10
Z4-VILLA
Afghanistan
111
^incorrect, by pure namesake alone one can predict that limits over the Driveshaft bearing will be pushed to the max as soon as the "flex" disc over "flexes" from more torque than it was designed for.
I mean they didnt name the driveshaft the "flex driveshaft" they named the "flex" disc a flex disc because thats what it does....it flexes...as soon as I added headers everything went weak for the guibo (flex disc) ....So that's where rev shift comes in....no flex just go.....I just finished ripping through all the gears with dsc off on the Queensborough Bridge with no problems....I intend to drive this thing into the ground only to build it stronger.
I seriously suggest this mod to ANYONE dropping their exhaust to ddo any work ie; headers, clutch work, ssk, etc....
Revshift Replaces doubt with Polyurethane..... :-)
      06-12-2011, 02:12 AM   #11
Z4-VILLA
Afghanistan
111
I decided that Revshift should rename their flex disc, instead of calling it a guibo....they should call it a Dee-BO...lol
      06-12-2011, 02:15 AM   #12
Z4-VILLA
Afghanistan
111
Also, I will havee my old Driveshaft support bearing reverse engineered into a polyurethane composite within the same tolerancees as the UUC Motor mounts.....stay tuned...
      06-12-2011, 09:51 AM   #13
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Are you going to be going for modified half shafts too or do you think they are not as much of a problem on some of the E46M3s?
      06-12-2011, 10:18 AM   #14
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Cool, looks a lot better than stock. Got a link?
      06-12-2011, 10:26 AM   #15
Z4-VILLA
Afghanistan
111
I only heard of one person having a problems with half shafts......
If I can find a pair made of some rare alien metal I might get it.
until then I dont see that being n issue.
unless of course someone else chimes in with something of note
      06-12-2011, 10:27 AM   #16
Z4-VILLA
Afghanistan
111
http://www.revshift.com/shop/index.p...d&productId=78
      06-12-2011, 03:59 PM   #17
Blind32
Blind32's Avatar
Drives: '07 Z4MC
Thanks!
What about the driveshaft support bushing mount thingy? Is that new one just another OEM one? Yours had worn out that much? ouch!
      06-12-2011, 06:40 PM   #18
Z4-VILLA
Afghanistan
111
unfortunately its just another oem.... a temporary fix for now as i am working on getting us a carbon fiber drave shaft which will eliminate the need for that bearing thingy
      06-15-2011, 07:51 PM   #19
Z4-VILLA
Afghanistan
111
i broke the driveshaft support bearing....again
      06-15-2011, 09:16 PM   #20
beta
That sucks. It can't be the extra power from headers/etc. as I haven't seen any of our supercharged folks breaking it, maybe something else is going on.
      06-15-2011, 09:24 PM   #21
Z4-VILLA
Afghanistan
111
idk.....maybe the red uuc mounts and tranny mounts are hurting the bearing?
      06-15-2011, 11:49 PM   #22
Z4-VILLA
Afghanistan
111
flex disc is money.....the support bearing....not so much...it lasted 4 days
