      06-16-2011, 09:00 AM   #23
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Sounds like something else, man, that thing was beefy. Did they have a max rating for it?
      06-16-2011, 09:22 AM   #24
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
no you must have miss understood.....i broke the hanger bearing which was the oem replacement.....the Revshift disc is awesome
      06-16-2011, 10:05 AM   #25
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
How did you notice you broke it? Did the car feel different or did you just look?
      06-16-2011, 10:13 AM   #26
Z4-VILLA
Afghanistan
111
vibration fromr previous breakage was duplicated after 4 days of hard running....
      06-16-2011, 12:34 PM   #27
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Yeah, forgot you had to replace that as well; the OEM bearing must count on some amount of slop, which you've taken care of with the other mods.
      06-16-2011, 12:38 PM   #28
Z4-VILLA
Afghanistan
111
all mounts motor tranny and guibo have been upgraded.....been on the phone all day with different parts of the US to try and make a polyurethane stamped driveshaft bearing so i can run that while i wait for my carbon fiber driveshaft......annoyed is what i am right now
      06-16-2011, 12:40 PM   #29
Z4-VILLA
Afghanistan
111
oem rubber on these cars is retaredly stupid and prone to failure.
whats worse is due to the rare nature of the car we cant get awesome aftermarket parts for the little things like this because our production numbers are waaay under 10k units on the planet
      06-16-2011, 02:10 PM   #30
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Your issues really don't sound like a Guibo or support bearing related.
Sounds to me like either driveline misalignment or excessive diff (tranny)movement.
I can understand that the Guibo and Bearing may fatigue in time, but the fact
that your support bearing failed so quickly mean there is a lot of driveshaft movement.
I would check the angle of the Tranny vs. Driveshaft and make sure you diff/
diff carrier don't have any excessive play.
      06-17-2011, 01:58 AM   #31
Z4-VILLA
Afghanistan
111
i just rebuilt my hanger bearing thingy using hot glue because of its very tough and flexable nature when cooled......then i sprayed black header paint over it.....will post pics
      06-17-2011, 09:52 AM   #32
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
are you still interested in an ess blower or not? you haven't answered my PMs
      06-17-2011, 10:08 AM   #33
Z4-VILLA
Afghanistan
111
I just checked my private messagues and yes I am still interested
      06-18-2011, 07:14 PM   #34
Z4-VILLA
Afghanistan
111
i broke the rev shift solid guibo as well....
because i have a near new clutch and flywheel, im putting way too much snap to the ground....i was able to shear some clearance around the yoke side bolt carriers....i swapped in a stock guibo from turner and a stock driveshaft bearing....and i will try to properly break in the clutch.
epic
      06-18-2011, 07:23 PM   #35
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
epic
Damn, didn't think that was even possible. Any chance there is an issue with the diff itself? I'm just thinking, there is some hard core resistance, zero give now, I mean your mods don't seem so torque radical (yet).
      06-18-2011, 09:25 PM   #36
Z4-VILLA
Afghanistan
111
i think the stock guibo is awesome after everything ive tried....hanger bearing on the D/S.....not so much....i will be sending off a perfectly new D/S hanger bearing so that it may be duplicated in such a manner where all the rubber pieces that BMW provides us can be reverse "iron manned" into polyurethane
      11-23-2011, 02:16 PM   #37
Oldsie
Drives: TR4A...
I have a similar (5L40E) transmission with exactly the same output flange, that I'm swapping into an old Tr4, and I just don't understand how the flex disc attaches!!! The output flange is a shallow circular cup with 6 tapped holes, just like in your photos. But the flex disc only attaches using 3 bolts on each side. The yoke on the drive shaft side has 3 legs and 3 bolts. How does the flex disc attach to the transmission flange? I know this must sound stupid, but what am I missing?
      04-20-2012, 08:38 PM   #38
davesz4mc
Drives: 2007 z4mc
Blast from the past!!!
My center carrier bearing looks just like this one yikes!!!
      04-20-2012, 09:11 PM   #39
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Looks like your vibration mystery is solved.
      09-10-2012, 04:50 AM   #40
tikamak
Lebanon
58
So you recommend stock guibo ?
      09-10-2012, 05:01 AM   #41
Z4-VILLA
Afghanistan
111
I would stay with oem
      09-13-2012, 09:37 PM   #42
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
I missed the fix - So in the end was it just a new clutch and lots of enthusiasm?
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      09-16-2012, 04:32 PM   #43
Z4-VILLA
Afghanistan
111
oh yeah
