      06-15-2015, 09:11 AM   #1
SIMN
SIMN's Avatar
11
Drives: 3.0si Sapphire Black Coupe
Arrow SM tuning 3.0si, 293hp 360nm?
Hello, just wondering if someone tried this chip tuning from "SM chip tuning"? They promise 293hp and 360nm. Seem pretty high for a none turbo.
http://www.smchiptuning.com/1165/bmw-z4-e86-3.0-si-265
      06-15-2015, 08:27 PM   #2
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
That would be awesome! Please purchase and give a full report!
It looks like you need additional parts to get to maximum output. Otherwise their 20hp chip is in line with other chips like Burger power box which claims 14 hp and ESS or AA which can be even higher.
      06-16-2015, 10:46 AM   #3
SIMN
SIMN's Avatar
11
It looks like you need additional parts to get to maximum output. Otherwise their 20hp chip is in line with other chips like Burger juice box which claims 14 hp and ECS which can be even higher.
Yes thats right, well I'm going to tune the ECU to 283hk och 340Nm
      06-16-2015, 11:24 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
40 hp for a tune on a naturally aspirated engine is dreaming. With headers and a full exhaust, maybe 20-30 hp. You need significant hardware mods to make 40 hp.
Do before and after dynos.
      06-16-2015, 11:31 AM   #5
SIMN
SIMN's Avatar
11
20hp tune more realistic or still dreaming? Keeping the stock exhaust, I'm thinking of deleting the muffler but there is no hp gain there if so matter
      06-16-2015, 12:47 PM   #6
pokeybritches
2006 BMW Z4M  [8.50]
5 horsepower from a real tuner is about the max you can expect, unless you've deviated significantly from stock hardware. I wouldn't trust anyone that told me they could gain 20 horsepower on an otherwise stock car. Additionally, power achieved on a dyno can vary by 10 horsepower between runs. So, I could easily show my worst and best runs of the day, and without changing anything, show a 10 horsepower gain from doing "mod x".
Catless headers with relocated O2 sensors and secondary race cats (like HJS) will provide the most power gain without going forced induction.
      06-16-2015, 01:41 PM   #7
Huz-Z
Huz-Z's Avatar
I don't think 5 hp would be even noticeable on on one of these cars, although you would notice the time and effort you took to install the thing and dearly miss the money you spent on it.
Huz-Z
      06-17-2015, 09:12 AM   #8
SIMN
SIMN's Avatar
11
Why then do a lot of tuners promise +20hp then if its not possible? Or they do a lot of dynos and pick the best one and "sell" that?
      06-17-2015, 09:27 AM   #9
GuidoK
#buildnotbought
GuidoK's Avatar
11088
Drives: Z4 3.0i ESS TS2+
Also remember when you go for really high gains on NA engine tunes, that some tuners run insane advanced ignition timings.
Maybe good for the last few HP, but very very bad for your rodbearings.
There is only so much you can do with a NA tune, and ignition timing mapping is probably the most significant.
If you want to stay NA, go for headers/cams and maybe a ported head.
Those are mods that do make a difference, and you could maybe get 50hp max extra (with the same revlimit)
MVRS4.50
      06-18-2015, 10:18 AM   #10
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Seems like a 5% gain is not unreasonable. Manufacturers always set their timing low so that it won't knock on the worst gas it can expect to see in a particular country. I think this is why the 3.0si is rated at 265hp in Europe (instead of 255hp in U.S.), the octane is higher there. The tuners advance the timing so you essentially have to always use 91 otherwise knock could occur. 5% increase on 3.0si is about 14hp. Not huge but it's nice to say you are running 270hp.
      06-19-2015, 03:42 PM   #11
SIMN
SIMN's Avatar
11
You two say different?
      06-27-2015, 10:32 AM   #12
SIMN
SIMN's Avatar
11
Bump
      06-27-2015, 05:05 PM   #13
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
SM Tuning is located in Bosnia and Herzegovina. I could be wrong, but last time I checked that wasn't exactly known as a hot bed of BMW tuning expertise.
Top Down 365
      06-28-2015, 01:24 PM   #14
SIMN
SIMN's Avatar
11
Hehe I agree, but I know more shops offering about +15-20hp
      06-28-2015, 03:05 PM   #15
vachss
Drives: Z4 Coupe
Actual dyno data
Different tuner, but I posted this 5 years ago when I had my 3.0si tuned. 10 hp was what I got and I was told that was a "good" number for the N52 motor with no other mods:
      07-06-2015, 08:20 AM   #16
SIMN
SIMN's Avatar
11
10hp, does that make any difference?
      07-06-2015, 11:29 AM   #17
Steeler
Steeler's Avatar
2430
I think you would feel that seat of pants.
Looks pretty steady difference across the RPM range
14 torques is where you would feel it
      07-08-2015, 08:50 AM   #18
SIMN
SIMN's Avatar
11
Seat of pants? English is not my main language so please explain. 14NM do you feel? Im kind of new in this subject so please explain
      07-09-2015, 06:48 PM   #19
Steeler
Steeler's Avatar
2430
Hmm .........you will feel the difference without having actual data to support that feeling.
Anyone else care to elaborate?
      07-09-2015, 09:47 PM   #20
pokeybritches
2006 BMW Z4M  [8.50]
Dyno runs can vary by more than 10 horsepower between runs. That's not to say you can't gain 10 horsepower with a tune, and I'm certainly not saying the specific tuner that flashed Vachss' car is misleading. I believe it's a real power gain. But what a lot of tuners will do is post the worst baseline run (usually the first), and compare it to the best "tuned" run (usually the last unless the car is hot). That's why it's best to get independent third party dynos. The independent shop is only on the hook to give me a dyno, and it has no vested interest in what the numbers actually are.
Vachss' dyno sheet is believable because it's from a real dyno, unlike many of the MS Paint dynos that float around on vendor websites. Thanks for posting.
      07-12-2015, 11:18 AM   #21
SIMN
SIMN's Avatar
11
Okey, so you do support a chip then?
      07-12-2015, 03:40 PM   #22
Steeler
Steeler's Avatar
2430
Not sure I support a chip I do think they are hit and miss and as others have said the tuners will do all they can to build up their product on a webpage.
As you can see from my sig below I try not to go half way on anything when it comes to performanc mods.
A chip would not have been enough for me.
