Go Back   ZPOST > Marketplace > Sponsors Classifieds
      11-08-2012, 10:58 PM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
..::PSI::.. G-POWER Z4 NON M Supercharger System SK I
Basis: Z4 2.2i/M54, 170 hp (125 kW) increased to 230 hp (169 kW)/ 260 Nm
Basis: Z4 2.5i/M54, 192 hp (141 kW) increased to 260 hp (191 kW)/ 310 Nm
Basis: Z4 3.0i/M54, 231 hp (170 kW) increased to 333 hp (245 kW)/ 385 Nm
Kits Include:
- Ultra stiff CNC shaped supercharger bracket system made from cast aluminum including an extended support-aggregate belt drive for the superchargerīs drive
- Air Intake Manifold, racing air filter with flow optimized clean air intake with large diameters made from cast aluminum.
- Standard throttle valve is positioned in front of the supercharger inlet,this layout of the air mass control in partial load improves the fuel consumption.
- ASA T3-313 supercharger
- Supercharger lubrication through bypass from motor oil circuit.
- 1 x air/water recuperater with front mount intercooler.
- 2 x air collectors made from cast aluminum.
- Engine inlet manifold made from cast aluminum.
Boost level ~7.2 PSI
Fuel Management/Electronics:
- Adaptation of the software of the standard electronic engine control unite (BMW OBD remains fully preserved).
- 6 x fuel injectors with enlarged mass flow.
TOTAL: $ 8,400.00 with FREE shipping OR Installation at our facility.
      11-09-2012, 02:23 AM   #2
Beedub
the design o these g-power parts is imo oem worthy.... gorgeous stuff.
      11-09-2012, 07:55 AM   #3
Sean@PSI
Sean@PSI's Avatar
Yes it is!
      11-13-2012, 04:29 PM   #4
Sean@PSI
Sean@PSI's Avatar
PMs replied.
Tags
g-power, precision sport industries, psi, z4 g-power, z4 supercharger kit
