      12-16-2022, 01:23 PM   #1
1zpower7
Drives: BMW Z4
Stand-alone engine management system Upgrades for Z4M
There is a complete solution for the adapter/loom/wiring for Z4M?
AEM/Ecumaster/Haltech has E46 M3 support, not Z4M.
      12-17-2022, 07:26 PM   #2
CTMP4me
Drives: '08 Z4MC, '71 240Z with S54
mattfwalters has his own version done, comics69 was pretty far down the road to making one available via https://www.exelixis.fr/ but that effort was from 2017-2020 era, dunno where it all ended up (https://www.instagram.com/p/BW-aaiZBdEN/ was one teaser)
It's the usual "there aren't enough Z4Ms" reason IMO, the unique S54+MSS70 combo is why I'm thankful that Severn is around with stock ecu tunes.
      01-28-2023, 02:10 AM   #3
Beedub
yup... done and properly working here in the UK by the guy! hes also added to the loom so it can control run a DCT box! pretty damn impressive!
https://z4-forum.com/forum/viewtopic...38219&start=45
      02-25-2023, 08:18 PM   #4
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
Hey, that's me! Thanks for the shoutout.
Wiring diagrams for making the 70x-series AEM ECU work with the Z4M are in my build thread (here), but mine is an off-road-only build so I didn't try to retain factory gauges or anything. I know it can be done, because AEM's plug-and-play E46 M3 setup did, but I didn't do that last bit of work to make the 70x speak CANBUS to play nicely with the gauges. I am happy to share the tune currently loaded in my 708 as well, it is emphatically unsafe to run anywhere other than onto a trailer and to your local dyno because 1) I haven't finished dyno tuning it yet; and 2) my engine is not stock; but it starts, idles, revs, and drives well enough to get you started.
