      07-19-2014, 05:59 PM   #1
MakSmack
Drives: 2007 BMW Z4 M Roadster
Diagnostic Cable Information
Good day gentlemen,
I have a fairly specific question that I wasn't able to answer by searching threads.
I want to buy a diagnostic cable for my car, but I'm a little worried about the date of production disclaimer on most of the cables I'm seeing. They mention that cars produced after March 2007 may not be compatible.
My 2007 M roadster has a production date of August 2007, when I look it up on RealOEM.com. Does anyone know for sure that the standard/common BMW cable that you see every where, such as...
http://www.ebay.com/itm/BMW-USB-OBD-..._Tools&vxp=mtr
...will work with my car, since it's post March 2007?
Also, I've also noticed cables on eBay that mention they are compatible with:
1) Fast magistral D-CAN and PT-CAN (500 kbit/s)
2) Slow magistral K-CAN (100 kbit/s)
Which apparently makes it compatible with later models because of the fast D-CAN standard. I have no clue, or way of being sure.
Can anyone shed some light on this?
Thank you very much.
      07-20-2014, 12:14 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
This has come up before, and you're right, to my knowledge it hasn't been answered.
I did some research on the 3-series forum, and "some say" you should get the K+DCAN.
I think this (or similar) has you covered either way.
It's pricier than non-canbus. There are some listed cheaper, but it looks like they only come with INPA.
You want to make sure you get DIS and SSS (Progman), and probably NCS.
      07-20-2014, 07:54 AM   #3
MakSmack
Is there anywhere this software is available for a free download? Or does it require serial numbers or activation?
      07-20-2014, 12:47 PM   #4
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
I wrote a post about recoding the sound system from E86 (coupe) to E85 (roadster) values. In there, I remember suggesting where you can get the s/w.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-20-2014, 12:49 PM   #5
donoman
Rookie
33
Oops, I just checked that post and didn't elaborate how to get the files other than to search Google. http://www.zpost.com/forums/showthread.php?t=982412
I suggest not installing the file on your primary computer without a virtualized installation ... these things can be riddled with viruses.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-21-2014, 07:49 AM   #6
MakSmack
Thanks, I'm sure this link will come in handy when I'm trying to get everything working.
      07-22-2014, 09:47 AM   #7
MakSmack
Have you ever heard of someone "bricking" their Z4 trying to fool around with these tools?
      07-22-2014, 11:48 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
Only if you try to flash the DME. I think that program is called WinFPK. I stay away from it.
INPA and DIS are perfectly safe and great for diagnostics.
SSS/Progman is safe and good for setting simple things that the dealer would charge you up the butt for.
NCS is a bit of a faff, and I imagine you could screw something up, but I've never heard of anybody reporting that they did.
I haven't tried NCS yet, but I might when my halo LEDs arrive.
Haven't decided if I want to fart with it or just stick some resistors across them.
Have many resistors.
      07-23-2014, 07:59 AM   #9
MakSmack
Well my first and most important order of business will be to disable the seat belt chime. I also imagine that I'll probably need this to reset the oil change indicator.
So it sounds like I won't be harming anything by fooling with those settings.
I'm glad to hear that flashing the DME is not required for these procedures.
      07-23-2014, 08:45 AM   #10
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
No need for a tool/software to reset the oil change indicator. Go here
      07-23-2014, 07:21 PM   #11
MakSmack
Thanks.
I figured there had to be some other way to reset the indicator without hooking up a diagnostic tool...every other car on the planet can do it.
I just read through that thread...they were talking about 15,000 miles between oil changes...what!?...that's forever.
      07-24-2014, 12:13 AM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
Pretty much everybody changes it at the 1/2 way point.
Every 7500 miles, unless it's a garage queen, then once per year.
But only reset the indicator when it goes negative.
And it's good insurance for the ///M to send a sample to Blackstone Labs for an analysis, and watch for high lead, indicating rod bearing wear.
