      08-27-2012, 11:18 AM   #23
mexicobmw
Mexico
56
Drives: car
smellyborrelli how does the rpi compare to the diablos. drone 1-2.5k sound, etc??
regards
diego
      08-27-2012, 01:17 PM   #24
smellyborrelli
Drives: 2008 135i
its hard to compare , the RPis are a helluva lot louder. but in a very good way. The Diablos are perfect if you just want a little rumble on top of the stock sound. Both have some low RPM drone. It doesn't bother me though, I think some people on here are just sensitive haha.
      08-27-2012, 03:07 PM   #25
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
update.....
obviously had some drone with the rpi's. here is something you guys may want to try since it worked for me. go buy roxul acoutic batts and line your trunk with 1" of batting. i removed all my carpeting and plastic panels and put acoutic batt under everything. replaced all the panels and carpet (was much harder putting them back since it was tight with the batting) and the drone from 1-2nd is almost gone. only drone now is in high gears under load at low rpm. i say this reduced drone by 30%
im also putting in a trunk mat to flatten out the carpet closest to the seats since its a bit soft now which should also contribute some sound insulation as well. went for a drive and its noticably quiter in the cabin.
instagram: @ dubsesd
      08-27-2012, 03:14 PM   #26
mexicobmw
Mexico
56
Drives: car
thanks for the advise dubseed, I was planing on dynamat any pros-cpns vs the accoustic batts.
regards
diego
      08-27-2012, 03:15 PM   #27
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
dynomat wont take away drone. it will only prevent any panels from vibrating. the roxul will kill the sound.
      08-27-2012, 03:31 PM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
check out B-Quiet for various sound deadening/absorbing products.
http://www.b-quiet.com/vcomp.html
"Vcomp is a noise barrier composite consisting of a dense 1/8" vinyl based polymer barrier with a 1/4" thick foam decoupler. It has a total thickness of 3/8", weighs approximately 1 lb/sq. ft. "
I've used their dampeners before, they're great quality.
      08-27-2012, 05:20 PM   #29
mexicobmw
Mexico
56
Drives: car
dubseed could you please direct me to which roxul to buy to try and source it in mexico.
regards
diego
      08-27-2012, 07:08 PM   #30
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
roxul safe and sound, roxul noise and fire, or just regualr roxul R16-22. they are all pretty much the same thing
Properties:
Non-combustible stone wool insulation with melting point of approx. 1177°C (2150°F)
Easily cut
Excellent sound absorbency
Fire resistant due to its high melting temperature
Water and moisture resistant; does not absorb moisture to maintain insulating value
Chemically inert
Does not rot, promote mildew, fungi, or bacteria, or sustain vermin
CFC- and HCFC- free product and process
Made from Natural and Recycled materials
      08-27-2012, 08:18 PM   #31
seank
enthusiast
seank's Avatar
48
http://origin.kaboodle.com/hi/img/c/...=1326586833000
You could buy some ear muffs that are good to 105 db? Nothing like installing exhausts that are too loud to hear, but good for everyone else around you to hear.
      08-27-2012, 09:11 PM   #32
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
its not that loud. the mufflers sit directly under the cabin of the coupe, so you will hear resonance throughout. i personally think the stock exhaust is boring for this car. you obviously think otherwise. good thing they make more than one kind of exhaust to suit different wants. im sure the car in your avatar has a louder exhaust...
      08-27-2012, 09:24 PM   #33
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
      08-27-2012, 09:37 PM   #34
seank
enthusiast
seank's Avatar
48
Dubsesd. It was a joke. I don't have a stock exhaust either.
      08-27-2012, 09:51 PM   #35
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
What kind of exhaust do you have mounted? I didn't catch the sarcasm in your post. Sorry
      08-27-2012, 10:04 PM   #36
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
thanks for the vids dubs. i want one now haha. If i get one, im finding a welder to change the tips asap though!
SOLD: 2008 M Coupe
      08-27-2012, 10:09 PM   #37
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
At first I wasn't too sure about the tips myself. But I think they looks amazing in person when they are cleaned up and polished inside. I clean up my car weekly so that isn't a problem for me, especially since I don't drive in rain. My original plan was to buy another large tip from rpi and make them the same size, but I'm now leaning towards the current look
      08-27-2012, 10:49 PM   #38
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Would it be easy enough to weld on another larger RPi tip? Is the enough room for it without modification?
SOLD: 2008 M Coupe
      08-28-2012, 06:57 AM   #39
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
There is room. But you would need adjustable dkf hangers. It would be a little tricky separating and welding the tips together again without damaging the finish though.
      08-28-2012, 09:24 AM   #40
z4mcoupe
boon
z4mcoupe's Avatar
Drives: 4 wheels
Are there tunnels where you live? That was my fix for the drone issue for this exhaust. One time late at night, the second I punched the throttle as the car entered the tunnel in 3rd gear, brake lights around me lit up instantaneously...
      08-28-2012, 11:29 AM   #41
smellyborrelli
Drives: 2008 135i
hey Dub, how are your black badges holding up
? i cant make mine last more than 2 months without fading.. even with 3 heavy coats of clear. My car is my daily though.
      08-28-2012, 12:11 PM   #42
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
Mine are like new. But it's a weekend car and doesn't see rain. Mine are black chrome though
      08-28-2012, 02:46 PM   #43
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Good info here on reducing resonance. That is the issue, especially with the coupe, since the hatch area just acts like one big speaker/subwoofer enclosure. I suspect the hatch itself also contributes to resonance--a lot. Has anyone tried removing the trim and stuffing some of these deadening materials in there?
      08-28-2012, 03:19 PM   #44
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
i just used the roxul stuff in behind the panels and it made a noticible difference
