      06-12-2009, 03:02 PM   #1
Matty C
Matty C's Avatar
Germany
20
Drives: 2007 Z4 M Roadster, 2006 M3
Help with Dice Silverline Pro Install
I recieved my Dice Silverline Pro today. I am trying to install in the trunk and having problems finding the correct connectors. Can someone give assistance after viewing the photos? Thanks for the help.
      06-15-2009, 11:13 AM   #2
Tapatio
Tapatio's Avatar
Drives: 2010 Z4 35i
2011 BMW 335d  [0.00]
2006 BMW R1200RT  [0.00]
The wires are probably under the console box (the first picture, above where your hand is). I have a 2007 3.0si and the wires were wedged under it. I had to stick a screwdriver under the box and raise it a little to pull them out.
      07-15-2009, 04:46 PM   #3
M-Al
M-Al's Avatar
Drives: 08 e90 M3
Removing trunk covers
Hi,
how did you remove the cover off your battery. Sorry to Jack your thread but I was unable to find any info and own a m roadster just like you.
Cheers
      07-20-2009, 11:09 AM   #4
M-Al
M-Al's Avatar
Drives: 08 e90 M3
problem solved by removing three rivets at base of battery cover and three bolts on the top...
