      05-17-2009, 12:56 PM   #1
Machster50
Drives: 2004 Z4 2.5
Automatic Softtop not working
Hi Folks:
Just taken the car out from winter storage and the top isn't working.
It will unlock using the 'top down' button, I can hear the little motor trying to pull the top down, if I assist manually it helps and then goes down, but no way can it bring the top up.
Is the weak motor a sign it's toast?
And reading the posts below, sure sounds like the same issue.
Where can I get this motor?
      05-22-2009, 10:06 PM   #2
Shipkiller
Shipkiller's Avatar
Drives: Me
Sounds like your motor is gone.
You can get it from your local dealer or on-line from several parts houses...
I use BMW Partz Direct a lot.
http://www.trademotion.com/partlocat...?siteid=214760
or Tischer
http://www.trademotion.com/partlocat...72&catalogid=0
      05-23-2009, 08:06 PM   #3
Machster50
Drives: 2004 Z4 2.5
Great - thanks bud - will take a look. Dealer wants about $700
      05-23-2009, 08:09 PM   #4
Shipkiller
Shipkiller's Avatar
Drives: Me
I bought my motor from the dealer.
The motor and new housing (you will need this) was only $560.00
