      07-15-2017, 02:11 AM   #1
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
Continental Extreme Contact DW, 284/40 x 18, nearly new
USD 275.00
Two Continental Extreme Contact DW, 284/40 x 18, nearly new, one trip from SF to San Diego and back, no measurable tread wear.
$275 for the pair, less than half price. These tires were nearly $300 each when new.
See https://sfbay.craigslist.org/sby/wto/6220239035.html for pictures because of the forum's usual picture uploading nonsense.
Extreme traction on the street. Longer treadwear than Michelin PSS. Nice smooth ride and just as sticky as the Michelin PSS anywhere other than very illegal speeds on a race track.
Selling because they scrape a little on my stock E86 M Coupe's inside rear wheel wells when driving over big dips with street alignment, just barely a little bit too big. More negative camber and or stiffer than stock springs will be fine. (I'm using -1.7 degrees. -2.0 degrees or will be fine.)
Also great on recent model M cars, Ford Mustangs, Corvette's, Camaros, Big V8 Dodges and similar.
Voice calls only, (323) 487-2002, this phone does not receive txt msgs.
And you may ask yourself, "Where is that large automobile?"
