      05-30-2010, 09:02 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
Drivers's Airbag question
Hi -
I recently swapped my wheel and switches for new ones. Removed the airbag module as per DIYs here and TIS instructions. No problems, on and off were easy. All cables replaced, all switches work, horn works. However the airbag indicator is now lit in the instrument cluster.
Double-checked all cables this AM. Any other ideas? Is this just a code that needs to be cleared?
thx
RC
      05-30-2010, 09:31 PM   #2
mhughett
Drives: 2007 Z4 M Coupe
I'm guessing that when you changed your wheel, you didn't remove the negative cable to the battery? This is step one of most DIY's for steering wheel replacement because if the computer senses that the airbag has been removed, the light goes on--even if all plugs and switches are correctly re-installed. I think the only thing you can do is have the light reset but I think this requires a separate tool from the standard Peake tool. Not sure if you can do it without a tool or without taking it to the dealer. Good luck.
      05-31-2010, 09:36 AM   #3
blender
Custom User Title
blender's Avatar
Drives: black
Actually I did pull the Neg lead and waited 30 minutes on the dot before working. I even hit the radio and dome light before I pulled the 'bag to make sure there was no juice in the system. Pretty sure that's not it.
Any idea if cycling the battery off/on again would clear the light? I kinda think not. And it's a pain to get at in the M: three plastic screws, three metal screws, cover.
thx
rc
      05-31-2010, 10:03 AM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
For the air bag system I don't think cycling will clear it.
Any change that the bag wiring connector isn't quite snapped in?
      06-01-2010, 05:09 PM   #5
blender
Custom User Title
blender's Avatar
Drives: black
Update - it was a code. Clearing the code solved the problem. Don't know why it THREW a code, given that the Batt was disconnected for 30min prior to removing the module, but all's well now. Cost me $20 and five minutes at my local bimmer mechanic.
Tags
airbag, airbag fault
