04-09-2011, 01:43 AM | #23 |
///M-fanatic
193
Rep 3,885
wow so with shorter tires, I might be able to fit 255's...interesting indeed!
I think I'm currently using 245/35/19's. That means, I'd need to look for 255/30/19's? Hrmm.....therein lies the issue haha. Will hafta tire shop next time around |
04-09-2011, 09:12 AM | #24 | |
Rep 1,373
Yep go for the 255/30/19. It is what I am running up front on my street wheels. Fits perfectly. Interestingly I mounted my rear OEM ZCP with a 275/30/19 front tires on the front last weekend and it fit perfectly also. I think I will be changing to run four OEM rear ZCPs in the near future.
07 Z4 M Coupe AW/IR |
04-09-2011, 10:35 AM | #25 | |
Rep 1,135
04-09-2011, 10:39 AM | #26 | |
M52, M62TU, S50US, S54, S65
75
Rep 569
I didn't know we could squeeze in so much beef up front! What offset should we run to make 265 or more up front and with how much camber? Also, where do you get the overall diameter info for each tire F360C?
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT 1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT 2002 E39 540i Protection |
04-09-2011, 10:49 AM | #27 |
Rep 1,135
04-09-2011, 11:08 AM | #28 | |
75
Rep 569
Now my order is 265/35/18 and 275/35/18.
04-09-2011, 11:12 AM | #29 |
Rep 1,135
yeee... you GOTTA let me know if 265s fit in the front lol. i ordered my 275 rears but didnt order fronts yet cause i was waiting for someone to try the 265s !
but you have coils and i have just springs so im thinking you have more clearance =/ |
04-09-2011, 11:37 AM | #30 |
75
Rep 569
get the turner motorsport shim kit! that will give you more neg camber and you should have more clearance.
04-09-2011, 12:17 PM | #31 |
Rep 1,135
04-10-2011, 07:14 PM | #33 | |
Track Head
24
Rep 503
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning |
04-10-2011, 07:56 PM | #34 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
I think he's getting them from DTD (DiscountTireDirect).
A set of NT-01s (245/40-18 & 275/35-18) are 907.54 Shipped from there. |
04-10-2011, 09:28 PM | #35 |
75
Rep 569
discounttiredirect.com! Well, I'm not a track expert, thus I don't want to go with R888 or NT01 so I won't get used to bad habits. But nonetheless, I'm very satisfied with my purchase. Can't wait to mount these tires!
04-15-2011, 08:01 PM | #36 |
75
Rep 569
Update: I just got these tires mounted to my apex and they look gorgeous! I have a little problem though... my rear tires (275/35/18 on 18x10 et25) are rubbing on the fender on sharp turns. up front, no rubbing, no nothing with 265/35/18 on 18x9 et42. So what should I do? Should I raise my car or should I roll my fenders?
04-15-2011, 08:15 PM | #37 |
Rep 1,739
Drives: 2008 Z4MC
Wow but your fronts fit w no issues. Now that changes things.
04-15-2011, 08:49 PM | #39 |
75
Rep 569
I'm not sure if someone with stock springs would rub... with the drop my car sits at -2 degrees camber... I was thinking of adding the shim kit from Turner to go -3 degrees, but I would have to run spacers to avoid touching the strut tower.
04-15-2011, 10:49 PM | #40 |
Track Head
24
Rep 503
I put my wheels on today.
18x9 +42 with a 245/40/18 NT01 , I've got a BBK which clears no problem, but am running 4 degrees of camber, so I had to add a 12mm spacer to clear the inside of the tire away from the strut (TCK Coilovers), appears to be no rubbing now. These tires have a wide contact patch for sure. 18x10 with a 275/35/18 NT01, absolutely no issues, car sits very nice all the way around. Can't wait to get out on the track tomorrow and see if I can make good use of the extra grip (was at the limits of the NT05, especially in Advanced Solo where I'm chasing people on R6's and blues trying to fend off the red myst).
04-16-2011, 07:39 PM | #41 |
Track Head
24
Rep 503
245/40/18 and 275/35/18 are NT01 working great for me at the track this weekend. Running a 12MM spacer up front to clear the shock with 4 degrees of camber (could likely get away with less spacer but didn't have anything hubcentric available smaller). Rear 275/35/18 are rubbing just slightly on the inner fender, a quick baseball bat roll job should solve this (It's literally just barely shaving the sidewall vertically).
Compare tire specs, I would be less concerned with the size, and more concerned with overall diameter and contact patch, these NT01s are very wide given their specs, and the traction shows.
04-20-2011, 01:53 AM | #42 | |
707
Rep 7,850
The NT01s like a lot of camber too IIRC. -4 up front might be a bit much for Star Specs or NT05s I think and -2.5 to -3.0 might be a better setting given those tires, yes? |
04-20-2011, 09:44 AM | #43 | |
Track Head
24
Rep 503
I ran -4 up front with the NT05s for 6-8 track days and found they love the extra camber as well (I actually got 12-13k miles + 4 or so track days out of my first set of NT05s running this setup with limited toe) . If you're driving on the street, obviously go less, but for the track, these cars love front camber.
04-23-2011, 08:59 PM | #44 |
75
Rep 569
Ran the NT05 today on the track and they performed less than what I expected. The weather was around 90 degrees outside and the tires were greasing up very fast. I guess I'll use them as my street tires and buy Hankook rs3
Tags |
hankook rs3, track, yokohama advan ad08 |
