08-15-2011, 08:42 PM | #1 |
Rep 11,667
DIY - Secure the loose Windshield Washer bottle
I was in the middle of a bunch of things on the weekend.
While I had things apart, I decided to secure the washer bottle a bit better. I found two issues. 1. there is only one screw that holds the entire thing in place. 2. the socket at the bottom of the tank was very loose fitting. I did two things; 1. added some hi-density expanded foam at the bottom socket. 2. used a big zip tie around the entire tank to secure it. End result; the tank is solid as a rock. The pics..... At the left arrow, I cut a small notch to keep the zip tie up. At the right arrow, there is already a small notch in the black shield in a perfect spot.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 08-16-2011 at 08:47 AM.. |
08-15-2011, 09:18 PM | #3 |
Rep 11,667
too soon.... not done playing yet
08-15-2011, 09:31 PM | #4 |
Rep 1,373
I am no better... I still have to go out and take some pictures with my inTgr8r/APR front splitter.
07 Z4 M Coupe AW/IR |
08-15-2011, 11:48 PM | #5 |
Viper Driver
36
Rep 1,311
neat diy, thanks for making the effort! i've noticed how loose fitting the windshield washer bottle itself is in the engine compartment too. figures i don't even use the windshield washer system (for fear the front headlamp washers pop up and the tabs get blown away in the slipstream).
08-16-2011, 06:43 AM | #6 | |
Rep 11,667
It's a separate circuit. You can see in one of the above pics, i stripped out the headlamp washer system as well.
