11-16-2016, 01:39 PM | #23 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Already had it done on 2 S54s so I won't be the first. But there is a great improvement. I should have done a video or a set of pictures before. I will just do it in the spring when I send mine out.
EDIT: found a picture.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition Last edited by Daemonblitz; 11-16-2016 at 01:50 PM.. |
inTgr8r2425.50 |
11-16-2016, 01:42 PM | #24 | |
Rep 2,866
I've also noticed the disappearing of the infamous "3k rpm vanos rattle" as well after the Beisan disc installation. Although, I also did the other Beisan stuffs (rattle and seals kits) at the same time. |
11-16-2016, 01:46 PM | #25 | |
Commander
221
Rep 850
hub tabs, some may be more worn than others, without Beisan actually having the exhaust hub I am sure that they just drill the disks all the same diameter, so some will have more play than others.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
11-20-2016, 11:01 AM | #26 |
Rep 753
The RRT tabs don't look welded on. They created a machined piece that bolts to the factory hub base. If they were welding, it would have been easier and cheaper to go the TT route. I'll double check with them on Monday.
They do have them on a few track M3's for a while now. |
12-13-2016, 04:06 PM | #27 |
1621
Rep 4,294
Does not look welded on from that picture. I too went the besian disc and multitude of other refresh offerings for the s54 by them and I must report that things are now quiet as heck. Needs a few more miles on it to loosen everything up.
Sadly I did not make the 60 day return/refund service.
Powered by |
12-13-2016, 04:36 PM | #28 |
salty cowboys fan
6158
Rep 3,406
Try giving them a call anyway, I was over too and they still took mine
she’s home! '22 M4 Comp xDrive
