      06-16-2016, 11:28 AM   #1
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Removing the back of the seat... anyone ???
Has anyone tried removing the backs of their seats? I want to try removing it to see if I can get a little more recline out of the seat as I'm 6'4".
Thoughts/suggestions??
      06-16-2016, 02:35 PM   #2
tkeneklis
Drives: 2005 Z-4 roadster
2005 BMW Z4  [0.00]
I have tried to put the back of the seat back into position and it was a PITA problem. You need to grab it by the sides and lift straight up. I don't think you get much room by doing this.
      06-21-2016, 12:46 PM   #3
tominizer
tominizer's Avatar
Hmmmmm, still think I'm going to give it a try. I need to go on REALOEM and see the part.
      06-21-2016, 05:39 PM   #4
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
This?
Instagram: ariusen26
Youtube: Track vids
      06-23-2016, 10:54 AM   #5
tominizer
tominizer's Avatar
^ Hmmmmm, little more involved than I was hoping to get !!!
      06-23-2016, 03:20 PM   #6
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
I removed the speaker grill behind the seat to get a little more clearance.
      06-23-2016, 06:28 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I've been considering this.
At 6'0" I fit, just, but my Son's 6'5" and still growing.
How ugly is it? Have any pics?
Any other downsides?
      06-23-2016, 07:21 PM   #8
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
With the seat in position you can't see its missing. Had it this way for 6 years without issue.
If you were to remove it with the seat set in a more forward position it is noticeable if you look for it.
      06-23-2016, 07:55 PM   #9
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
If you decide to take off your seat back, would you mind taking a few pics, especially of the area where the seatbelt guide screws into it? I have a screw that just spins. I'm tempted to pull the seat back, but I understand it can be a bear to get it back on. Thanks!
Salty
      06-30-2016, 11:08 AM   #10
tominizer
tominizer's Avatar
I will do. I haven't gotten around to starting this project yet. Too many other things in life cropped up recently. but I will get around to it and I promise to post up some pictures.
      07-20-2016, 11:26 PM   #11
fishboy
Drives: z4
i removed the speaker grill and the back of the seat. you can move the seat back a bit. can't see the open gaping hole since it's back all the way. : )
