03-12-2011, 10:51 AM | #23 | |
Car Geek
3626
Rep 3,593
Any lead-acid battery that is not completely sealed (i.e. has a vent tube or caps of any form) will out-gas hydrogen. If it has been stressed, it will produce enough hydrogen that could trigger a small explosion in a confined space when a spark is introduced. Using the correct procedure for connecting cables to the battery will eliminate that (even though small) risk completely and costs nothing. BTW, our Z4M's use a wet AGM technology that is halfway between a conventional lead-acid battery and a gel cell in terms of electrolyte solidity. |
03-12-2011, 11:27 AM | #24 | |
Rep 11,667
Ignoring the light weight genre, are there any good non-OE replacements?
03-12-2011, 01:00 PM | #25 |
///M-fanatic
193
Rep 3,885
Clamp the Negative (-) terminal, follwed by the Positive (+). Shouldn't cause any issues
Then when you're done, reverse order: remove the Positive (+) first, followed by the Negative (-). |
03-12-2011, 02:03 PM | #26 |
Rep 1,110
exactly, ground it first (-) , connect the power (+), then disconnect the power, and disconnect the ground last. safest way. just dont let the leads touch anything else while either battery is connected. i usually isolate the clamps/ terminals by wrapping a rag or something around it loosely
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
03-12-2011, 02:32 PM | #27 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
I take my battery of and I put inside the house. I test and charge as needed never had problems that way.
03-12-2011, 02:57 PM | #28 | |
Car Geek
3626
Rep 3,593
http://www.batterystuff.com/tutorial_battery.html#3 |
