      01-05-2009, 05:35 PM   #1
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
obd2 code p110d ??? what is that?
I scanned my ecu with my scangauge and received a P110d code. there was no check engine light but I can't the interpretation for this code. anyone help??
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      01-06-2009, 09:20 AM   #2
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
not for the same car but the codes are probably the same. looks like a fault in the throttle position sensor.
http://www.bmwclub.info/_files/codes.pdf
      01-07-2009, 12:13 PM   #3
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
You're a life saver!!! Thanks, I never would have found that!!
      01-07-2009, 11:05 PM   #4
ATX750i
ATX750i's Avatar
Drives: 2009 Honda Civic Si
2003 Z4 2.5i  [0.00]
What is year is your M? I know another member that had his throttle position sensor go out all together.
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD
09' 2.0 Polished Metal Metallic Honda Civic Si - Current
      01-08-2009, 11:07 AM   #5
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
Mine is an 06. But I don't think it's a faulty sensor but the nitrous kit I installed which is tapped into the TPS wire. I need a resistor to isolate it is all
      03-13-2011, 06:28 PM   #6
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
i just got the same code today....
      03-13-2011, 06:29 PM   #7
Z4-VILLA
Afghanistan
111
It reads exactly like your and mine is an 06 M Roadster...
P110D
      03-01-2021, 08:14 AM   #8
Nipperjam
Drives: E90
Hi I have a 320i and have a half engine light reduced power and the 2 fault codes are p110d and 2cf8 and they don't clear all I have done recently is add some door sill leds wired to the floor lights can't see that causing any problems any help would be appreciated I've removed and cleaned throttle body air sensor in air box and airflow meter behind throttle body
Search this Thread:
Advanced Search
