      01-14-2014, 07:49 PM   #1
604skyline
Drives: 2020 M2 CS
better front setup/offset (18x8.5 et30 or 18x9.5 et40)
'08 m coupe, on stock suspension for now, either going with the ohlins group buy if it ever happens, if not I have a full JRZ Pro on the back burner.
the new volk ze40 will be on their way to me from japan....
so what is the better front option?
18x8.5 et 30 or 18x9.5 et 40?
the rears I am going with 18x10.5et20 so...
      01-14-2014, 08:14 PM   #2
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
I personally would run 9.5 with a 10+ mm spacer.
      01-15-2014, 05:00 AM   #3
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
x2
      01-18-2014, 01:29 AM   #4
Beedub
I'd run the 8.5 et 30.... That'll tuck in nicely with camber, look great and give no rub....
      01-18-2014, 02:25 PM   #5
gmd2003
gmd2003's Avatar
352
I'd do the 18x9 , then you can run 265's up front without a spacer , no problem . This my track setup, so I'm running -3 camber with 0 rubbing .
      01-19-2014, 12:44 AM   #6
Barryb97
Drives: 2006 M coupe
I Would love to run 265's up front. 18x9 what offset?
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      01-19-2014, 08:27 AM   #7
gmd2003
gmd2003's Avatar
352
EC-7 by Apex 18x9 ET 31 . They also clear my 355 mm BBK up front .
