03-22-2016, 05:07 PM | #1 |
Rep 2,782
Update 5/3/2016 - Solved! It was the yaw rate sensor, located under the passenger seat. I bought a $29 part from a junked Mini and fixed it in about an hour. DIY to follow.
Anyone have details? I've found conflicting information online as to whether this is a wheel speed sensor or yaw rate sensor. Yellow brake, yellow tire pressure, and yellow triangle are illuminated. SES light is illuminated due to rear O2's being disconnected. The fault could not be reset with a dealer-level tool, meaning it's present at startup (sensor is disconnected or completely toast). If it is a wheel speed sensor, does anyone have an idea of how to determine which one it is (short of pulling out each sensor and testing it with a multi-meter)? I've read that the driver's side rear wheel speed sensor is where the speedometer and odometer pull their information. Both seem to be working fine. When I display vehicle speed on my P3Cars vent gauge, it will hop around for a split second on rare occasions, but reads accurately 99.9% of the time.
03-22-2016, 06:45 PM | #2 |
636
Rep 3,124
You have INPA, don't you?
I've wondered whether it will give you individual readings off each speed sensor. Or maybe DIS will tell you specifically which one is bad, or if it's yaw rate.
03-22-2016, 07:30 PM | #3 | |
Rep 2,782
03-22-2016, 07:34 PM | #4 |
Rep 2,704
I had the trio once, right after an alignment.
It went away of its own accord and never returned
03-22-2016, 09:13 PM | #5 | |
Rep 2,782
03-24-2016, 07:42 PM | #6 |
Rep 32
I have the same 3 yellow lights after removing my nav screen to repaire the plastic housing. Before removal the screen was working, hooked it back up after repairing housing, no display and had the yellow lights. Will be very interested to see what you find out.
03-25-2016, 10:51 AM | #7 |
Rep 2,782
I ordered a rear wheel speed sensor. I'm going to try replacing the driver's side first, and test the old and new one with a multi-meter. If there's no change, I'll try the passenger side, testing that sensor.
If there's still no change, I'll test the front sensors. Finally, I'll look into testing the yaw rate sensor. On E46's, it's under the driver's seat. I'm not sure where it is on the Z4. After that, I'll take it to a shop.
03-28-2016, 09:12 AM | #8 |
Rep 2,782
Good news - I replaced the rear sensor, and it's a fairly easy job.
Bad news - I still have the amber trio, so I'll probably just replace all the sensors. After 13 years and 140k miles, it can't hurt. Bavauto has them for ~$40 each. I would need to rig something up or buy new probes to test the sensors with a multi-meter. The sensor's blue plastic cap is too deep, and it gets in the way of the probes. For this DIY, I'm replacing the driver's side rear sensor. 1. Remove the wheel. The sensor is behind the brake rotor. 2. Find the sensor. 3. The sensor can be removed with a 5mm allen key. 4. Unclip the wiring. 5. Continue to follow the wiring over the river and through the woods. Do not try and pull the sensor through. The other end is smaller, and we will pull it out from front to back once we unclip the other end. 6. Eventually the wiring disappears behind this wheel liner cover. The cover is secured with two 8mm screws on top, one 10mm plastic bolt on top, and one 8mm screw on the bottom. 7. Looking underneath the car, in front of the wheel at the rocker panel, you will see the 8mm screw on the bottom. You don't need to remove any other screws on the bottom of the car. 8. After removing the liner cover, locate this black box. You will need to pull off the rubber drain to access it (not shown). 9. Inside the box you will find the blue plastic connection for the wheel speed sensor. Remove it, and pull out the wiring from the black (allen key) sensor end. Remember to route your new wheel speed sensor before connecting it, since the black end is too large to be routed correctly.
05-04-2016, 03:08 PM | #9 |
Rep 2,782
05-04-2016, 03:14 PM | #10 |
Rep 2,782
For now:
1. Photo of sensor under seat (seat removed). Make sure you disconnect the battery before unplugging the seat. 2. Photo of old and new sensors. I had to swap from the Mini bracket to the Z4 bracket.
05-04-2016, 04:48 PM | #11 |
Rep 11,667
Excellent!
Glad that you got it sorted out.
05-06-2016, 06:12 PM | #13 | |
Rep 2,782
