05-10-2010, 01:32 PM | #1 |
Rep 316
Z43.0si advice needed
hey all,
first time poster. i am in the market for a 07 z43.0si. had one inspected by BMW, they came back and said "Engine lower cover has broken mounting points" also had lower battery, power window not working. it was a 07 lease with 17k on it. the carfax, autocheck came back clean. does it sound like the owner beat it? not sure how you break mounts or why a new car would have electrical issues.... any feedback/thoughts would be awesome! thanks shawn |
05-10-2010, 01:38 PM | #2 |
///M'n it Up
17
Rep 344
Sounds like the engine cover got dinged up and subsequently the little screw mount tabs for the cover were broken off.
The battery can simply be replaced. The power window might be a regulator, motor or switch. Fairly common stuff on BMWs. You're better off checking for the major things, like water damage and maintenance history. |
05-10-2010, 01:45 PM | #3 |
Rep 316
Thanks for that. I'm still waiting to speak with the mechanic who checked it out.
Im not to savy with cars, so thank you again. He also said that 2 wheels are "slightly bent" as well as the steering wheel being off center to the right. Just seems like alot for a 07 with 17k, unless your really beating it. oh, btw this Z43.0si is selling for 26k which is why i was suspicions. seems lower than most that ive come across. shawn |
05-10-2010, 01:50 PM | #4 |
///M'n it Up
17
Rep 344
Yea, bent wheels is never good. There has to be a pretty big impact to make that happen.
The steering wheel being off center is just an alignment issue, that can be fixed. Definitely not a garage queen. But cars are meant to be used. Stuff happens. And 26k isn't a "great steal". You can get a M for just a few thousand more. |
05-10-2010, 01:54 PM | #5 |
Rep 316
are electrical problems are common on BMWs?
one of the power windows does not work. right blinker does not work. just hope this isn't a sign of a bigger issue. thanks again for your replies! |
05-10-2010, 02:46 PM | #6 | |
Rep 1,143
Too bad I just traded in my car :\ |
05-10-2010, 03:14 PM | #7 |
Rep 316
why a gamble?
i thought they are always serviced by BMW & owners have to return in good condition? just talked to the mechanic. said the mounting points for the hood isnt a big deal. pretty much said overall nothing major. the warranty will cover the blinker/battery. said the "slightly bent" rim is very slight and common with flatruns. said the window is a "program" fix. im not purchasing from him, this was a 3rd party inspection, so im leaning towards purchase. the only thing that will need fixed is the flat run tire in front. has a bubble. |
05-10-2010, 03:29 PM | #8 |
BMW Fan
11
Rep 553
Unless it's an auto and that's what you want, I would spend a few thousand more and get a Z4M. This car sounds like it was beat on and poorly cared for, and for the dollar, the Z4M is a better value.
05-10-2010, 05:14 PM | #10 | ||
Rep 1,143
http://mmsc400.manheim.com/MABEL/ECR...8&locale=en_US Most if not all of these issues are fixed by the dealer before the next person buys it as part of the reconditioning process. For many people that's not a big deal, but the quality of the work can certainly vary. Personally, I'd like to find a used car with as much factory paint intact as possible. Quote:
Regardless, the 6-speed manual is a must. |
05-10-2010, 05:56 PM | #11 |
Rep 316
thanks guys. in the end im going to pass on this since my gut tells me the last
owner didn't really take care of it. i love the M, but think the 3.0si is more suited for what im looking for. curious if anyone has opinion about buying CPO? thanks again shawn |
05-10-2010, 08:46 PM | #12 |
Rep 137
Drives: E91, Lemans Blue
I picked up a 2007 Z4 3.0 coupe with 5800 mi for $23500. One owner, pretty mint. The battery issue happened to me over the winter. Put it on a trickle charge and dealer fixed the transport mode. A/C would not work until this was corrected. Take your time and enjoy looking for the right car. To me that is all part of the hunt. As far as an M or 3.0si. It is purely personal. Good luck.
