      02-12-2013, 03:09 PM   #1
aakash421
Drives: 2005 bmw z4
Connecting to Bluetooth
Hey Guys,
I am having issues connecting to bluetooth. I have taken pictures and attached them all in order, with the steps I take to connect.
Turn on car (I should have a minute to connect from when car is on)
Hit R/T Button, which will tell me to connect phone
Click on car bluetooth on phone and enter last 4 of VIN as the pin to connect.
Then I get an error.
I have an Iphone4S and it is compatible according to bmwusa.com
Thanks.
      02-12-2013, 03:23 PM   #2
mike519
mike519's Avatar
Drives: 2018 M240i
It's not the four digits of the vin. You should have a white card with a pk code on its, that's the pin. If you don't have it, it's stamped on the bt module behind the rear "firewall" carpet.
      02-12-2013, 03:44 PM   #3
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
I haven't done it yet, but I've read the easiest way to read the PK code is by taking out the drivers side subwoofer behind the seat. You can shine a flashlight in there and read the code on the box.
- Wes
2007 BMW M Coupe
2016 VW GTI
      02-12-2013, 08:59 PM   #4
aakash421
Drives: 2005 bmw z4
If you see the pictures I posted, it says the pin is correct, is that error wrong?
I am kind of a nub, where and what is the bt module and where and what is the "firewall" carpet?
      02-13-2013, 05:47 AM   #5
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
The error message is saying "make sure the PIN is correct".. In other words, the error message is reading like this..
Please make sure:
1. BMWxxx is ready to pair
2. The PIN is correct
- Wes
2007 BMW M Coupe
2016 VW GTI
      02-13-2013, 10:52 AM   #6
aakash421
Drives: 2005 bmw z4
No that is not what the error is saying... unless you want to explain its implying the opposite of what it is saying.
I can try the other pin, I looked behind my seat and I do not know how to take the sub out. I tried to wedge in a pen to pop it up but that did not work.
      02-13-2013, 11:01 AM   #7
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Agreed with elwesso. The PIN code is NOT the last 4 digit of your VIN.
No...the error is telling you to make sure the PIN code is correct.
      02-13-2013, 11:20 AM   #8
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
Search is your friend.
http://www.zpost.com/forums/showthread.php?t=663900
http://www.zpost.com/forums/showthread.php?t=312258
http://www.zpost.com/forums/showthread.php?t=509127
http://www.zpost.com/forums/showthread.php?t=423635
- Wes
2007 BMW M Coupe
2016 VW GTI
      02-13-2013, 07:52 PM   #9
JFleming
Drives: '10 328i xdrive, '07 Z4 3.0si
BT Pairing code
It is printed on the module accessable from the trunk. You have to remove the carpet and remove the three nuts that hold the bracket. The bracket and module are on the drivers side.
      02-13-2013, 07:54 PM   #10
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
The subwoofer(s) in a Z4 is mounted in a closed cavity that will not provide any access to read the PK code off the TCU module. You will have to either get at the TCU from the hatch/trunk or have the dealer or someone with a scanner get it off the car for you.
      02-14-2013, 10:55 AM   #11
aakash421
Drives: 2005 bmw z4
I got the code, and the only thing that works through the bluetooth is my phone making a call. Is there a certain procedure I need to follow in order to play music off my phone or would this feature not be available? I tried hitting mode and playing with the R/T button.
      02-14-2013, 11:29 AM   #12
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
I don't think you can make music play off your phone via bluetooth in this car.
Just out of curiousity, how did you get the code?
- Wes
2007 BMW M Coupe
2016 VW GTI
      02-15-2013, 11:49 AM   #13
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
Phone only no music.
Steve
