      03-18-2012, 04:57 PM   #1
07z4ed
07z4ed's Avatar
Drives: 07 Z4 Roadster Triple Black
Getting to Bluetooth Code
I have an 07 convertible and the bluetooth code was lost before I bought the car. Stealership wants $65 just to hook up and read it. My understanding is that it's on the unit in the trunk, but I don't want to tear up the carpet of the little plastic plugs trying to get to it. Any suggestions would be greatly appreciated.
      03-18-2012, 06:41 PM   #2
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
The carpet is pretty tough. Here's a DIY that shows how to get all that stuff apart.
http://www.zpost.com/forums/showthread.php?t=497843
If you have a little mech ability and a basic set of tools (metric ratchet set, screwdrivers) you can get to the module. Pretty sure its the one that is in the bracket to the left of the hole in the Pics. Get the bracket off and your passcode should be on the TCU.
No third option Ive heard of, Do the R&R or its off to the dealer, wallet in hand - Sorry.
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      03-18-2012, 06:46 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
^WHS
      03-18-2012, 06:49 PM   #4
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
My dealer read mine for free.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      03-18-2012, 07:29 PM   #5
07z4ed
07z4ed's Avatar
Unfortunately, the dealers here in the Atlanta area value their money more than generating goodwill and possible future/referral business.
/s/
Ed Munday
2007 Z4 Roadster - WooHoo!!
      03-18-2012, 07:30 PM   #6
07z4ed
07z4ed's Avatar
Thanks for the replies. I'll check out the link from BruceJ.
/s/
Ed Munday
      03-18-2012, 10:43 PM   #7
mitchsf
Member
Drives: 2006 Z4 3.0si Roadster
I just pulled mine to read the passkey. It' on the left side, behind the carpet. The sticker with information is on the front, so the TCU had to be removed from the bracket, which is really no problem. The hardest part is reassembling the carpet connectors.
It is also a good time to install a Dice or Intravee modlue while the carpet is off. Also, my car had a big piece of foam, approximately 10x6x5" that was glued to the rear carpet, and it had fallen off. I reattached it with velcro.
      03-18-2012, 11:28 PM   #8
mousitch
Dark Sider
mousitch's Avatar
129
I hear ya. Sorry
      03-19-2012, 11:20 AM   #9
07z4ed
07z4ed's Avatar
Thanks for the additional info!
/s/
Ed Munday
      03-20-2012, 02:11 PM   #10
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
I wonder if it is VIN related. My passkey is very similar to my last 4 digits of the vin. Can others take a look and see if they see a pattern?
The Raspinator
      03-20-2012, 09:12 PM   #11
JFleming
Drives: '10 328i xdrive, '07 Z4 3.0si
passkey
No part of my VIN and passkey have anything in common.
      03-28-2012, 12:10 PM   #12
Ixice
Drives: 2006 Z4
Mine either...
      03-29-2012, 07:53 AM   #13
Skuronen
Skuronen's Avatar
Had this same problem, and also did not want to tear apart the trunk to get to this number.
Try going the other way. I removed the speaker grill behind the drivers seat and was able to spot the code with a flashlight. You may have gently push aside some wire bundles with a long screwdriver or the like.
Hopefully this may work in your case, I have a z4m coupe not convertible but I would think it is set up the same.
      04-04-2012, 11:30 PM   #14
greenspire
Drives: 2008 Z4 3.0si
BT Code
My dealer read mine for free and gave me the wrong number! They read it on the computer (supposedly) and gave me an 8 digit number.
I didn't realize until I tried to link my phone that it wasn't right.
Skuronen (above) and one other person suggested going through the speaker grill behind the drivers seat and I just did that and it WORKS! lol
With the grill off there is a very small opening on the right side (when facing the speaker opening) where you can see the TCU label which is most likely partially blocked from view by some harnesses. I covered a long screwdriver with heat shrink to eliminate any sharp edges and conductive metal and was able to push the harness aside and get the number. Phone is working! You will know when you are in the area when you see the Bluetooth logo and/or the letters PK which are just before your 4 digit code.
Many thanks to the guys who discovered this route!
If anyone wants to send me a note I can reply with photos.
The grill comes out with gentle prying with a plastic wedge of some sort. btw....this is the very large grill that has to come out! NOT the tweeter.
All the best.....
david
David
2008 Z4C 3.0si
Black on black
Sport/premium
6 speed
Last edited by greenspire; 04-06-2012 at 07:46 PM.. Reason: Updates for finding bluetooth code through speaker cavity.
      04-05-2012, 09:31 AM   #15
Huz-Z
Huz-Z's Avatar
For my car, there is no relationship at all between the VIN and the four digit bluetooth code.
If you try to see the code on the TCU unit in the trunk, look for the for-digit code that begins with "PK" and then the four numbers. A small digital camera taped to a stick could be handy, come to think of it!!!
Huz-Z
      04-07-2012, 04:04 AM   #16
Uncle Russ
Rocket Scientist
Uncle Russ's Avatar
Drives: '08 M Roadster
I, too, was able to recover my code by removing the driver-side subwoofer grill. I used a long-handled wooden spoon to gently move the harness and then used a small mirror (telescoping & articulated) and flashlight to read the code off the label. If I remember correctly, the label is upside down. Good luck.
2008 ///M Roadster
      04-07-2012, 08:36 AM   #17
Gripster
Gripster's Avatar
Drives: E93 M3
2013 BMW M3  [0.00]
I went the carpet route. Took me an entire afternoon to do it without damaging anything. Still bust a clip. BMW didnt really think this one through.
2013 M3 (E93) - ZPP/ZCW/DCT
http://www.bimmerfest.com/forums/image.php?u=26275&type=sigpic&dateline=1208140506
      04-08-2012, 01:40 PM   #18
greenspire
BT Code retrieval
Hello Uncle Russ,
That was my experience as well,.......the text is upside down on the label. All in all it's easier than tearing the trunk apart!
david
