      01-28-2019, 09:32 AM   #177
racerbruce
racerbruce's Avatar
3855
Drives: 21 X3 & 13 335is E93
YAY Matt!
You're freaking amazing - SO close to see and hear The Bronze Beast run!
Racerbruce
      01-28-2019, 10:08 AM   #178
53Fatman
53Fatman's Avatar
Germany
Drives: Z4 M Roadster
Glad to hear that Matt
Perfect solution to open the valve, no need to remove the housing. Hope to see that Motor running soon, awesome projekt!
      01-28-2019, 02:45 PM   #179
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Originally Posted by mattfwalters View Post
Water and oil at 10/11 C....you need to treat yourself to a heater in that garage!
      01-28-2019, 07:30 PM   #180
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
It is heated! I like it around 12-13 degrees when I'm working.
      01-28-2019, 11:37 PM   #181
mattfwalters
Well, shit.
I picked up a timing light and and remote starter trigger for next step ("once spark, make sure timing is good") but just for giggles before tearing apart the igniter wiring I threw in the #1 plug / coil and hooked the light up to it. Damned if it didn't just start strobing. So I locked the Infinity to 0* BTDC and as far as my eye could see the #1's spark timing was bang on the TDC mark on the harmonic balancer. I checked all 6 coils and they all trigger the timing light, so I guess I have spark.
Then I did a practical test for spark just because I wanted to see it with my own eyes:
View post on imgur.com
I triple-checked the injector config and the selection of the E46 M3 profile hadn't stuck (this seems to happen a lot with the Infinity, maybe because I haven't been explicitly disconnecting before shutting down, which I've started doing now), so tried that. No luck here either.
Okaaayyy... so I tied the throttle pedal down, stared through the butterflies at the injectors and hit the starter for a bit. I didn't see any twinkles of spray despite verifying on the log that the Infinity was commanding 0.3% duty cycle (I know, that's basically nothing, but..) so now I'm wondering if I actually have fuel. I smell fuel, but haven't ever seen pistons or intake ports glistening.
The other thing I'm wondering about is whether or not I might have the crank timing out by 360 degrees, but then I'd eventually be getting some big pops / fireballs out the headers, right?
It seems like there's just not enough fuel to make a bang. Sigh.
      01-29-2019, 05:47 AM   #182
racerbruce
racerbruce's Avatar
3855
Awe....ssssssshucks.
Crazy question....is the fuel pump suffering from the same symptoms/causes you experienced w/the oil pump?? Is priming of any kind necessary to initiate draw in the fuel pump system??
Is this way to fundamental for what you're trying to correct?
https://itstillruns.com/prime-fuel-system-7605700.html
Racerbruce
      01-29-2019, 08:05 PM   #183
mattfwalters
The fuel pump is definitely moving fuel around, I can hear it returning to the tank when the pressure hits 5 bar.
What you've made me think about, though (thank you!) is whether or not this dead-end system has a bunch of air in the rail... off to bleed...
edit: the fuel rail was full of air, but now it's full of fuel and that hasn't solved the problem. Starting to suspect a wiring issue with the injectors, so that'll be how I spend the next couple of hours I get in the garage.
      01-30-2019, 12:29 AM   #184
mattfwalters
gonna leave this here for the giggles
I also just loaded the diagnostic firmware and confirmed via practical test that injectors work (I have fuel sprayed on a shop towel, woo).
I'm wondering... the Infinity is reporting cam0 timing @ 213* and cam1 timing @ 634* which seems plausible if I got the intake and exhaust cams wired to the wrong inputs, which, if one assumes cam0 == intake and cam1 == exhaust, I did. But according to the E46 M3 PnP wiring diagram, they're correct. But according to the input setup, there's some shit Really Wrong.
Ugh.
end giggles. begin belly laughs
I had mis-wired the MAP sensor. Stupid late add that wasn't on the wiring diagram? Idiot.
BAHAHAHAHAHAHAHAHAHAHA IT'S ALIVE
      01-30-2019, 02:03 AM   #185
mattfwalters
So, I couldn't resist playing around with it a bit more. I didn't take more videos (sorry) but when it starts it just wants to rev itself to the moon. I put in a 2,500RPM rev limiter to keep it from really spinning itself up - but it's showing solid 12.4-13:1 AFR when it's doing so.
Weirdly it's way past the idle target (~1,400) and keeping the throttles at 10% or so, which is probably causing the revs given the good AFRs. I guess I need to look a bit more into how the Infinity handles idling and then start fine-tuning it. I may set a fairly high idle target since I'm probably not going to bother with the IAC.
Garage smells like exhaust instead of gasoline fumes now. It's a good day.
      01-30-2019, 08:32 AM   #186
racerbruce
racerbruce's Avatar
3855
The Bronze Beast Lives!!!!
YAY!!!!
This is a big day in the land of massive mods....well done!
Racerbruce
      01-30-2019, 10:43 AM   #187
53Fatman
53Fatman's Avatar
Germany
Congratulations Matt
@ 0:24 you got me
      01-30-2019, 11:47 AM   #188
mattfwalters
YAY!!!!
@ 0:24 you got me
Thanks, both! I'm... pretty stoked. No point in putting it any other way.
      01-30-2019, 11:52 AM   #189
WeekendWarriorz
WeekendWarriorz's Avatar
674
Drives: 2006 Z4M
Congrats Matt! :
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      01-30-2019, 03:28 PM   #190
mattfwalters
Originally Posted by WeekendWarriorz View Post
Congrats Matt! :
Thanks!
      01-31-2019, 12:19 PM   #191
mattfwalters
Some more grumbles from the car last night:
It was trying to rev itself out previously because I had given the idle logic 10% of the throttle position but the idle logic was configured to engage at max 5% throttle / 2k RPM... so it was revving itself up past idle and then somehow not closing the throttles.
It's really lumpy.
      02-01-2019, 12:02 AM   #192
racerbruce
racerbruce's Avatar
3855
Awesome!
i think I heard the Bronze Beast 20 miles away....where I live (:
Racerbruce
      02-01-2019, 02:39 PM   #193
mattfwalters
Awesome!
It is - shockingly - not that loud. That's probably because it's below 2k RPM.
We'll see how I feel about the noise level during the cam break-in that my engine builder just growled at me for not doing before trying to get it to idle.
Whoops.
      02-01-2019, 04:54 PM   #194
racerbruce
racerbruce's Avatar
3855
Cam break-in
Whoops.
What's the suggested protocol??
Racerbruce
      02-01-2019, 09:02 PM   #195
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Matt, congrats on the running mate, awesome job..
can't wait to see everything together mate.. one awesomely sorted Z4M. Hats off on the electrics man, that stuff scares the p-jesus out of me
Powered by
      02-01-2019, 09:06 PM   #196
mattfwalters
2,200RPM for 10 minutes, let it cool enough that I can lay a hand on the valve cover, repeat. Then drop and replace the oil and get it to a dyno ASAP for full break-in and tuning.
Thanks man! There's a long way to go for it to be sorted, honestly, but it will get there. I'm pretty jazzed to have it running on the Infinity - now I need to get the cooling system buttoned up and get the VANOS working.
      02-03-2019, 10:16 PM   #197
mattfwalters
Some good progress today, also some disappointments.
Plumbed the power steering cooler:
...except that the low-pressure return line to the reservoir isn't long enough. I'm going to use a 12mm barb fitting and use part of the stock one.
So then, I started the top rad support:
It's mostly sorted now and I'll tie it into the front brace in the near future.
Then I hung and wired the fan:
Another fun issue is that I deleted the heater core and the pipes that feed it. Turns out that's where the main outlet from the overflow tanks goes in the stock system. So I ordered another heater core delete kit from Bimmerworld and I'll just cap off the lower outlet from the tank.
Rad and engine have ~2gal of distilled water in them. Fan works. But I need to close up both the power steering and water systems, parts are en route for same.
      02-04-2019, 06:05 PM   #198
Michael9218
595
I had ordered that block off piece, but it didn't fit well at all on the Z4M heater pipe. Maybe you'll have better luck. I ended up taking to the local fabrication guy and he welded a cap on it after the pipe that returns to the overflow tank and the second bracket bolt point.
Here's a pic. It's painted black part way back.
