      07-23-2014, 08:24 PM   #1
Technobuff
Drives: 2004 E85 3.0
Headlight ballast access/removal
I bought a 2003 E85 (97k miles) with the right headlight out. I replaced the bulb then the igniter but headlight is still out. I believe that the last one to replace now is the ballast. if that does not work, any ideas. If it is the ballast, how can I access and remove it without removing the front bumper. I know I cannot take it out using the 2 access points from the wheel well.
Your assistance would be greatly appreciated.
Technobuff
      07-23-2014, 09:12 PM   #2
pungo
pungo's Avatar
I would be swapping parts from the working headlight to the non-working. It could be the wiring or even the LCM.
If you can't get the ballast off through the wheel well access panel, then the bumper probably needs to come off.
      07-23-2014, 11:42 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Yep, good advice.
DIY for bumper removal here, pretty easy to do.
