      06-01-2016, 10:45 AM   #23
Varinn
Drives: 2007 Z4MC
Does anyone have a recommendation for or against welding the reinforcement plates in? I have quotes for the repair in massively varied price ranges depending on the shop I've talked with (Anywhere between $350 and $1000). I'm thinking that so long as everything is kept tight that welding the plates to the towers is probably not required and it would add a good deal to the cost
1990 332i 5 speed (OBD2 S52 Swap)
2018 VW Golf R (6spd manual/copper orange metallic)
2008 KTM SuperDuke 990
2007 Z4M Coupe (#1026/1815) SOLD
      06-01-2016, 12:45 PM   #24
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Varinn View Post
So the studs arent long enough to run the STB and the plates together? What mounts are you guys running? I kept the oem top mounts for comfort purposes
Also no brace or bottom plates before, I had been tossing and turning on wether to get it or not...
This is mainly a KW issue.
Most camber plates have studs that are long enough.
      06-01-2016, 12:48 PM   #25
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Welding is not necessary.
The added strength around the stud location comes from the thicker metal.
If it was the whole tower that was flexing, then welding would be beneficial.
      06-01-2016, 02:44 PM   #26
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Send KW an email, they have longer studs available.
      06-01-2016, 07:44 PM   #27
Varinn
Drives: 2007 Z4MC
I don't have KW coilovers. I'm running Bilstein B12's on oem mounts right now, debating ground control plates but not yet decided. Will get it fixed and see how the budget is. Still need to investigate why my struts were not matched for camber side to side.
      06-02-2016, 01:13 PM   #28
Varinn
Drives: 2007 Z4MC
Well, the bad news is that the strut tower brace is officially NLA. Tischer just emailed and cancelled my order. Guess I'll be looking for a used one or going aftermarket!
      06-10-2016, 02:46 PM   #29
Arrgo1
Not so new member
Arrgo1's Avatar
Drives: 2006 M Roadster
Get a Strong Strut Brace. Very functional and great looking
http://www.strong-strut.com/Z4.htm
      06-22-2016, 02:12 AM   #30
N55_Mike
N55_Mike's Avatar
Drives: 135i, Z4MC, MK7 GTI
Bimmian.com has a Mechinik Strut brace for the Z, looks awesome too!
