05-17-2015, 08:44 PM | #2 |
Rep 1,031
Define the noise. Creaking, whoosh from air, thump, bump, etc.
They are nosier than stock suspension. Did you tighten the end links tight enough? That will make a thump sort of sound at low speed and over bumps.
05-18-2015, 12:34 AM | #3 |
Rep 12,565
End links, play in fcab, rear shock mounts...
05-18-2015, 05:03 AM | #4 |
Rep 5,328
my clubsports are silent. after a hard track day when everything hot i can hear some noises but on normal road use, nothing at all, just my teeth banging together.
05-18-2015, 06:26 AM | #5 |
Rep 11,667
Mine were never silent on anything but a smooth surface.
05-18-2015, 11:14 AM | #6 |
Rep 5,328
mine are silent 98% of the time id day.... and I've only heard the noise I'm describing on the road that leads off the track, its like a bumpy dirt track. i love these coilovers!
05-21-2015, 11:52 AM | #7 |
Rep 23
Thanks All,
Comparing with KW V3 and BILSTEIN PSS10 now. KW doing 22% off special at my local dealer now. It's cheaper than PSS10 in here, but i like the BILSTEIN that adjustable dampening knobs from the bottom. If price is the same, the KW V3 would that be better value than BILSTEIN? Thanks for all answer. |
