      02-04-2011, 11:15 AM   #111
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by esqu1re View Post
Argh. With a full tank of gas, yours is still in the 3200's. Mine is pretty much stock, and it must weigh 3300+ with a tank of gas. Sad face.
Yup, I remember weighing in @ 3360-3380 when the car was completely stock, with a full tank of gas.
Plus driver, it's still quite a hefty car. But at least it's got potent power hahah
      02-04-2011, 12:43 PM   #112
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Originally Posted by Eccentric View Post
interesting... didnt realize the standard bat weighed that much. Any cons to this?
You would have to make sure you charge the battery when you're not driving it for a week or two. Some people have had a small battery put in with no problems, while others have had some problems. If you're daily driving yours, and you need it to be very reliable, you might reconsider swapping out to a lighter battery. If it's a weekend driver or a track star, I say go for it.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      02-04-2011, 12:47 PM   #113
mfanatic325
///M-fanatic
Taiwan
193
Yeah it depends on your locale too. Warmer places typically don't have as much of an issue. It all comes down to cold cranking amps whether or not you can start your car after sitting idle for a week or so at a time.
      02-04-2011, 03:45 PM   #114
RBull
Drives: 2007 M Coupe
that should be a range of 40 lbs.
Originally Posted by mfanatic325 View Post
With full tank of gas and all the mods listed in my signature (excluding APR splitter), my car weighed in @ 3220-3240 (scale is + 20 lbs.)
      02-04-2011, 06:24 PM   #115
mfanatic325
///M-fanatic
Taiwan
193
lolol nonono. The scale was back and forth between 3220 and 3240, which is why I said "3220-3240 with + 20 lbs." haha
My hunch is that it falls somewhere like 3230 right in between
      03-08-2011, 02:32 AM   #116
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
This weekend I removed the rear retractable cover mechanism. I've been wanting to do this for a while. It weighs 7.5 lbs.
I will get the car on a scale again this week.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      05-13-2011, 03:11 PM   #117
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Is it easy to remove? I never use the cover.
      05-13-2011, 05:23 PM   #118
Jbs
The Photographer
Jbs's Avatar
Drives: 07 Z4MC BSM/Black extended
aren't there a few (cheaper) alternatives to the batteries mentioned above? like odyssey and the other super-light ones
John Batte Photography / Flickr / Facebook
2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob
      05-13-2011, 07:55 PM   #119
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
I'm using an odyssey for the past 2 yrs. It doesn't hold a charge after 2 weeks so it sits on a trickle charger but there are no issues beyond that. I forgot the model number but here's a pic
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      05-13-2011, 11:24 PM   #120
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
the model # is inprinted on top
      05-14-2011, 12:48 AM   #121
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
It unbolts easily but... it's a real pain to remove all the plastic trim in order to get to the bolts that hold it in place. I imagine it will be even more of a pain to put it all back again but I haven't done that yet.
      07-07-2012, 04:44 PM   #122
mfanatic325
///M-fanatic
Taiwan
193
Just FYI, I weighed in the other day at 3140 lbs. with 1/8th tank of gas and mods listed in sig.
