      07-27-2010, 10:40 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
19 x 9.5 et20 are these STICKING OUT?
on stock M suspension, I'm worried that with 285 wide tires mounted, they're gonna stick out way too far out of the fenders. Anyone else running this setup? am I better off with 19 x 9.5 et33?
      07-27-2010, 11:09 PM   #2
vortex_tuning
Drives: E92 M3
On stock M suspension, 19x9.5 ET20 will only stick out 2-3mm at most. They will look much better than 19x9.5 ET33. 285 tire might look too fat on a 9.5" wheel. IMO, 265 and 275 fit better.
      07-27-2010, 11:13 PM   #3
ZStig
279
yeah, it looks like around 3mm, but I'm guessing the tires will add another 3-4mm =(
      07-27-2010, 11:54 PM   #4
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Should look pretty good, not extremely aggressive.
Most guys run 9.5 between +20 and +25.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      07-29-2010, 01:17 AM   #5
M2audioman
Drives: 2018 M2
you're fine with a 19x9.5 +20, but you might need to stick with a 275 tire to be safe. I had 19x10 +25 on mine with 275's and it was perfect. I might have been able to squeeze 285's on there, so you might be able to as well. It won't stick out though. It will be flush with the fender.
      07-29-2010, 08:11 AM   #6
crfine88
crfine88's Avatar
442
Drives: E86M
I don't recommend 285's on a 9.5" rim.
These sizes fit without rubbing.
Fronts 19 x 8.5 +38 w/ 1.5" Stepped Lip
Rears 19 x 10.0 +34 w/ 3.0" Stepped Lip
Tires - Nitto Invo 245/35/19 and 285/30/19
See this link for a members HRE set up.
http://www.zpost.com/forums/showthre...&highlight=hre
Saw these in person. They looked great and fit with no modifications to the fenders.
      07-29-2010, 12:53 PM   #7
M2audioman
Drives: 2018 M2
19x10 +35 is still too tucked in. The optimal setup for this car is:
19x8.5 +32
19x10 +25
You can give or take 2mm for either the front or rear offsets if you'd like, but those are optimal.
If you have to use 19x9.5's in the rear, then you would want a +20 offset. In all cases though, a 285 tire is ok if you are on stock suspension and depending on the tire brand you use since some 285's are narrower than others (i.e Falken 452's). If you are lowered and dont want to run neg camber to compensate for the larger tire, then just stick to a 275. In addition, the 275's will be lighter tires as well.
      07-29-2010, 12:56 PM   #8
M2audioman
Drives: 2018 M2
Lastly, here are pics of my old BBS LM's with the optimal offsets/tires
http://www.zpost.com/forums/showthread.php?t=122993
      07-29-2010, 09:37 PM   #9
ZStig
279
unfortunately, I trusted a vendor with the recommendation, and the tires are already mounted. But yeah, the rears are 19x19.5 et20, and they stick out about 10mm with the tires on =/
I guess I'll get an aggressive fender roll to make it look better
      07-30-2010, 06:31 AM   #10
crfine88
crfine88's Avatar
442
Drives: E86M
If you are going to do the fender roll, PM me. It is easy to get wrong on our cars.
I can give some pointers that will save you a lot of heartache.
      07-30-2010, 08:45 AM   #11
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
Post some pics, I promise not too make mexican comments
      07-30-2010, 10:43 AM   #12
ZStig
279
I also got the wrong front wheels in the mail, so I'll only have them on the car after August 9th
      07-30-2010, 12:43 PM   #13
Jbs
The Photographer
Jbs's Avatar
Drives: 07 Z4MC BSM/Black extended
damn roffle, youre moving quickly lol
wheres that supercharger though?
John Batte Photography / Flickr / Facebook
2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob
      07-30-2010, 01:01 PM   #14
ZStig
279
I know I know. I HAD a buyer lined up for my stock wheels, so I though, what the hell might as well sell and upgrade. Buyer changed his mind, started ignoring me, now I'm stuck with wheel problems. I'm sure the vendor will work something out for me though...
I still need another $3k for my blower fund
      07-30-2010, 01:56 PM   #15
ZStig
279
can this be fixed with a fender roll?
      07-30-2010, 02:50 PM   #16
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
Take a few steps back... from there its hard to tell, but I would say it would look kinda mean. Or like a mexican :P
edit: no offense to anyone, around here most of the hispanics that work on their cars have their wheels sticking way out. Like a good six inchs or more.
      07-30-2010, 02:57 PM   #17
JPWEraser
Drives: 2016 Corvette Z06/Z07
Nothing that some suspension mods and a fender mod couldn't fix.
      07-30-2010, 04:12 PM   #18
ZStig
279
h&R springs?
      07-30-2010, 07:53 PM   #19
apexstrafer
Drives: Z4 M Coupe
Perhaps you could use a set of these flares...
(half joking)
      07-30-2010, 08:15 PM   #20
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
yikes, better watch for the curbs when you park, might touch the wheels.
      07-31-2010, 08:33 AM   #21
RBull
Drives: 2007 M Coupe
Shame you got bad advice. That set up is way too wide. If you put lowering springs on you couldn't drive down the street without major rub.
      07-31-2010, 08:39 AM   #22
JPWEraser
You would want some suspension mods that would allow you a large range of camber adjustability as well as a good fender roll to be able to tuck that much wheel/tire, but it can be done. The real question is - how hardcore do you want to get with it? I fit 18x10" wheels on my STi but the rear fenders had to be pulled, cut, and I had to hammer out the wheel well to go as low as I wanted to go. All that was on top of coilovers with camber plates.
