      07-08-2010, 03:36 PM   #1
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Help/questions with rims
Hey guys,
So I have a 2003 2.5 Tsilver with the sports package. So I'm assuming its factory lowered. I'm looking to change my 17in rims to something else.
I was thinking of going 19in, but I'm a pretty aggressive driver and I'm in NYC, most roads are broken or not very smooth. I'm afraid they might crack or the ride would just be terrible. correct me if I'm wrong.
So I figured I'd go with 18's. I was looking into the VMR v710 gun metal.
http://www.jlevistreetwerks.com/Whee...duct_info.html
or maybe something from modbargins, the m6 style one's
Now I don't understand how the spec's for wheels work, I tried googling with no luck. Some people have different back rims vs front, etc
And what do the numbers mean?
"Front: 19 x 8.5 +34
Rear: 19 x 10 +26
Nitto Invo tires
Front: 245/35/19
Rear: 275/30/19"
So what would be a good set up spec wise with tires for my model.
not to much wheel well space but not rubbing on turns either.
Also, since I won't get run flats, do you guys carry a spare in the trunk? or should i get a 5th rim and put it in the trunk?
Thanks in advance, sorry for the novice questions.
Amir
      07-08-2010, 04:09 PM   #2
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Rear: 19 x 10 +26
Nitto Invo tires
Front: 245/35/19
Rear: 275/30/19"
That is called a staggered setup when the rear wheels are wider than the front
19 is the size of the rim.
8.5 & 10 is the width in inches of the rim.
the +## is the offset
http://www.tirerack.com/wheels/tech/...jsp?techid=101
offset is one of the most important specs for proper fitment.
245 & 275 is the width of the tire in mm
35 & 30 is the size of the side wall which is a % of the width (245 & 275)
so the side wall is 35% of 245. This is also called profile, ex low profile tire.
19 is the size of rim it fits.
      07-08-2010, 04:13 PM   #3
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
best break down ever!
Thank you!
      07-24-2010, 10:42 AM   #4
vortex_tuning
Drives: E92 M3
For your application, 8.5" ET30-35 and 9.5" ET42-45 staggered wheel setup should work well.
      07-25-2010, 07:46 PM   #5
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Thank you vortex
      07-25-2010, 07:57 PM   #6
fercho
fercho's Avatar
Drives: 2005 z4 2.5
do you guys know what size of tires can i use on my rims?? im plannig to buy 19"
Size: 19x8.5 Front / 19x9.5 Rear
what size of tires do u recoment for daily drive??
what offset???
thank you
      07-27-2010, 10:27 AM   #7
JD3
Drives: 09 e92 M3, DCT.
Trickiest thing I've discovered with wheels is offset. It's a simple enough concept, but it's easy to get screwed up when converting inches to millimeters and there's some simple, but important math. For example, just b/c the offset is the same, doesn't mean they'll fit. You also have to take into account the wheel width.
I don't know for sure, but I'm guessing a 10" wide rear wheel with a +26 offset is a little too aggressive unless you want to seriously stretch your tires.
But I may be wrong.
      07-28-2010, 12:59 AM   #8
fercho
fercho's Avatar
Drives: 2005 z4 2.5
thank!! what size if tires do u recommend??
But I may be wrong.
      07-28-2010, 04:40 PM   #9
JD3
I'd suggest looking at what other's are running. It depends on how conservative/aggressive you want to be. I'd do 225/35 and 265/30, but that's just me.
      07-29-2010, 07:45 PM   #10
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
I purchased the 18x8 18x9 wheel set.
Wondering If I need spacers for these http://www.**********s.com/Avant-Gar...Silver-BMW.htm
z4 2.5, I read some people say a 12mm will flush it out evenly with the fenders.
Any recommendations?
