      01-20-2010, 03:10 PM   #1
jehsautosalon
Drives: z4 m roadster
Question HELP!! clutch almost gone.. in less than 49,900mile
Got my car last May of last year and it was a CPO with 46,0000 miles.. then I felt that the clutch was little heavy while driving it in a Big City Traffic.. i ask my local dealer to check on it and they said that the clutch is almost gone.. And it was not cover by the warranty. I just wanna know if this is the truth.. Is clutch wear not covered by the warranty?
      01-20-2010, 03:36 PM   #2
Erhan
Erhan's Avatar
Drives: Cooper S
As fas as I know, it is not covered.
      01-20-2010, 04:02 PM   #3
DarkstarZero
DarkstarZero's Avatar
Drives: Daytona 95 M3, X7 M50, e92 M3,
I thought it was covered by the maintenance plan, not the warranty. The clutch in my gf's Mini went at 28,000 miles because it's her first manual and she destroyed it The Mini dealer replaced it free of charge, no questions. BMW should do the same unless your maintenance plan has expired.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center!
Enter Referral ID: 420186
      01-20-2010, 05:46 PM   #4
sirmalloc
code monkey
sirmalloc's Avatar
Drives: 2006 Z4M Roadster Imola/Imola
what does a typical clutch replacement cost for the M's?
      01-20-2010, 06:08 PM   #5
jehsautosalon
It's gonna be 3,000$ something... With labor and everything.. Isn't the just bad!
      01-20-2010, 06:30 PM   #6
jehsautosalon
http://www.bmwusa.com/Standard/Conte...otCovered.aspx
check this out..
      01-20-2010, 08:44 PM   #7
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
if thats the case and its not covered, bring it to a reputable bmw indy. it will be much cheaper
      01-20-2010, 10:26 PM   #8
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
^ $3000 is crazy.
I mean most clutch installs here cost around $300-600 for the labour - and a good clutch is usually less than $500.
Should go aftermarket for the clutch if they are available will probably be much cheaper compared to OEM
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      01-20-2010, 10:29 PM   #9
The__J__Factor
Australia
88
Drives: ///M Coupe
Wait more importantly is the clutch even gone? Does it slip?
Drive in a straight line in 5th at a low rpm like 2000rpm and floor it. Does the tacho jump up without picking up any speed? Thats probably the easiest clutch test.
135i N54 manual
      01-20-2010, 10:52 PM   #10
jehsautosalon
its still runs good and well.. its just not soft and low.. kinda high clutch only but not gone..
T_J_factor: so if the tacho jumps without picking up speed is that means the clutch is good or bad?
      01-20-2010, 11:19 PM   #11
jehsautosalon
but base on our Service and Warranty page 29.. CLUTCH Wear and tear is covered by new car warranty.. and my car is still under 50k miles.. So, it is still covered by it.. Will find out tom..
      01-20-2010, 11:23 PM   #12
The__J__Factor
Australia
88
Drives: ///M Coupe
If the revs jump up it means the clutch is slipping. Meaning its worn out and needs to be replaced.
If the car just accelerates slowly and all is normal it means your clutch is still holding on just fine.
135i N54 manual
      01-21-2010, 12:52 AM   #13
DarkstarZero
Right, since it's under 50k miles and less than 4 years then it's still within its new car maintenance/warranty. Because whoever you talked to didn't know that I'd either go to a different dealer or ask to talk to the owner. Never hurts to go straight to the top You can get the owners name from the dealers website. Or call BMW NA, they can tell you and the dealer if it's covered.
      02-03-2010, 10:46 AM   #14
BlackSapphireZ
Drives: 22 GLE 53 Coupe
yeah let alone that it has been CPO'ed, they probably didn't wanna fix the clutch or just over looked it
2022 GLE 53 Coupe
