      12-11-2013, 10:45 AM   #1
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Meguiars Prices at Autozone
For the cheapskates like me who wonder if they could save an extra dollar by comparing Amazon to brick and mortar stores.
Prices for Meguiars Mirror Glaze products carried at Autozone are below. These prices are in PA, but shouldn't vary much from state to state.
#26 Hi-Tech Yellow Wax (16oz) - $13.99
#7 Show Car Glaze (16oz) - $14.49
#9 Swirl Remover 2.0 (16ox) - $15.99
#205 Ultra Finishing Polish (32oz) - $29.99
#2 Fine Cut Cleaner (16oz) - $15.99
#1 Medium Cut Cleaner (16oz) - $15.99
#105 Ultra-Cut Compound (32oz) - $33.99
      12-11-2013, 02:54 PM   #2
Phishman
Phishman's Avatar
Drives: Beige car
Do you really need all of those?
      12-11-2013, 03:02 PM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
no he's just publishing prices for people to compare for whatever product they might need
      12-11-2013, 08:38 PM   #4
KevinC
your average JAMF
KevinC's Avatar
Ugh.. much prefer Chemical Guys nowadays.
'21 M2 Comp
'19 Golf R
      12-12-2013, 08:17 AM   #5
jdoublehcubed
Mechanical Engineer
Mirror Glaze - still the gold standard of professional detailers everywhere.
      12-12-2013, 09:01 AM   #6
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
CG is good, but M105/205 is the best polishes on the market right now.
I have 7 Menzerna Polishes sitting on my shelf compared to M105/205 which I use most of the time now.
Prices are a bit more than detailedimage or similar...but for a convenience factor those could work
      12-12-2013, 10:24 AM   #7
jdoublehcubed
Mechanical Engineer
How often do you find yourself using M105? My experience is all with less aggressive compounds. I know 105/205 is the combo everyone recommends, but I've never found myself needing something with as much cut as 105.
      12-13-2013, 10:52 AM   #8
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Hey guys, you seem to know a little about this stuff, I've got some swirls in my paint (obviously need the swirl remover) but how do you recommend to apply it??
      12-15-2013, 09:52 AM   #9
jdoublehcubed
Mechanical Engineer
Vanne,
I would highly recommend a dual action polisher like this:
http://www.harborfreight.com/6-in-va...her-69924.html
Its easy to use, and totally safe. Unlike a rotary polisher, you can't hurt the paint with a dual action polish. The clutch will stall out before you can heat up the paint and damage it.
I'm guessing its tough to get harbor freight stuff in Dubai. The polish I recommended above is also sold by Meguiars, Griot's Garage, and Porter Cable. They all have different labels on them (and will cost about twice as much as HF), but they are the same polish, same motor, etc.
This chart will help you decide what compound you need:
http://www.auto-geek.net/charts/wax-...art-master.htm
I would guess something between 3 and 7. Unless your paint is really trashed, you don't need something as strong as #105 Ultra Cut Compound above. And if you can't get Mirror Glaze products, the Meguiars Ultimate Compound and Ultimate Polish are very similar forumlas, and I've worked with both in the past with good results.
If you're going to do the buffing by hand, it might be easier to use something with more cut (closer to a 7 on the charge above).
Good luck!
      12-15-2013, 11:48 AM   #10
Kgolf31
Kgolf31's Avatar
460
I only used it once on my Z4M. It was when I bought it, PO took good care, but obviously needed some work.
It has been 3 years since M105 has touched the paint. I'll probably detail this winter again and stick to M205 and PO85RD on the paint to just clean it up
      12-15-2013, 12:35 PM   #11
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
jdouble, wow mate, that chart rocks. thanks for that, I've got a black n decker random orbital buffer that i picked up a while back, but have been too afraid to use it yet.. ill probably stick with the meguires number 3 swirl remover as the paint is actually in quite good nick.
Ill hopefully try and have a go over the next 2 weeks or so, depending on what the missus has planned for me.
so if i start with the swirl remover, and give that a bash, then what should i follow it up with? do i need to reseal? or should i just wax over after that and be done with it?
Powered by
      12-15-2013, 01:51 PM   #12
chickdr
Drives: 2006 M Roadster
Typically wash, clay, polish, seal, wax. Some go to further extremes with less aggressive polishes before sealing.
      12-15-2013, 04:56 PM   #13
Real Nice Guy
Real Nice Guy's Avatar
31
Drives: 2008 e90 M3
Although I do use Mequiars 105 as a third step correction to go after those deeeep swirls, I absolutely hate using those products... Terrible, I mean terrible work time. I am a bit of a detailing snob so if its available at Auto Zone or Advanced I tend to stay away....
Check out Detailers Domain for good prices on worth while products!
They are located in northern New Jersey, shipping would most likely only take 1 day to PA.
I was going to recommend Menzerna and Sonax products but it seems like your trying to save money..... sorta opposing ideas being you own an //M
      12-15-2013, 05:28 PM   #14
Kgolf31
Kgolf31's Avatar
460
Really, just because M105 is offered at Autozone you think it is crap? lol
I'm sorry, but that is just funny.
Jim Brown Method with M105/205. If you don't think you can work the product well, you aren't doing it correctly.
      12-15-2013, 07:29 PM   #15
Real Nice Guy
31
Drives: 2008 e90 M3
Maybe I worded it worng but no, thats not what I said.... I even mentioned I still USE 105
But the idea of going to Autozone for "detailing" products reminds me of somebody who would overpay for cheap MF towels, buy a paint damaging water blade, drill attachment for headlight resto, or other shit consumer products like black box wax....
Yes, Meguiars has been around for a long time, they have some good products.
Why short yourself with what is available at a local car parts store??
There is no denying 105 can cut but has a very short work time! There is a reason they give you such a big bottle
And for that price I can think of a handful of other compounds that will cut harder, finish better, and have a longer work time.
      12-15-2013, 08:05 PM   #16
Kgolf31
Kgolf31's Avatar
460
I disagree. And there is a fairly good reason why I have Menzerna PG and SIP sitting on the shelf collecting dust when M105 gets the call from the bullpen
I have Wolfgang, Chemical Guys, Poorboys, Klasse, Dodo Juice...etc all in my garage. Just because it is offered local doesnt mean it should be looked down upon.
PS - If you want something better, Meguiars M101 is out on the market. Have fun paying for that pricetag though.
      12-15-2013, 11:02 PM   #17
jdoublehcubed
Mechanical Engineer
Vanne,
Really it depends what your results are after using the swirl remover. You might find yourself wanting to use some #205 polish afterwards, but swirl remover is already very low cut, almost to the point of being a polish, so you may not need it.
If you decide to do it by hand, maybe use the Meguiars Ultimate Polish instead of #205. Its a bit easier to work by hand.
After polish just wax as normal. I've never used the #26 yellow wax above, I like the Ultimate Paste Wax.
You also could do a Glaze in between the polish and wax, but I would probably only go through the effort of doing a glaze if it was a full out detail, with clay before hand, careful attention to every little detail (clean and treat ever rubber spot, under license plate, etc., you know what I mean). Applying Meguiars Glaze is a lot of effort, I would reccomend googling how to apply it if you choose to do so, because it doesn't work like a polish or wax.
Good luck! Check out autogeek.net if you want to learn more above obsessive level car detailing.
And I'm only going to make one response to the other comments above, other than to agree with Kgolf31. Those drill headlight tools are right at home in a professional's detailing bag; they're the perfect tool to apply final plastic polish after a 7 step wetsand (400/600/800/1000/1200/1500/2000).
      01-09-2014, 11:33 PM   #18
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
hmm, they only carry SwirlX here.. ill give that a try
Powered by
