      09-16-2008, 10:02 PM   #1
DirtBag335
DirtBag335's Avatar
15
Drives: 07 Z4M
New Mod
I got these in a few weeks ago, hopefully they will be put in this weekend. I have a friend who works for BMW so luckily I get all the work done on my car cheap. They are 4.10's that I got from diffsonline, not sure if anyone has dealt with them but they have great cusotmer service. Here is a pic I took of the ring and pinion in case anyone is wondering what it looks like.
      09-16-2008, 10:11 PM   #2
MMMazing07
MMMazing07's Avatar
180
Drives: Z4M
sweet! i have to drive a car with 4.10s to see if i really like it
      09-16-2008, 10:15 PM   #3
DirtBag335
DirtBag335's Avatar
15
Drives: 07 Z4M
Ya I'm really excited to see if it's as good as everyone says it is. I will be sure to post back in this thread about what I think. Looking at that pic the pinion looks rusty but in really life it's shiny and clean....
      09-16-2008, 10:38 PM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
And I thought the car was short as it is.
      09-16-2008, 11:23 PM   #5
DirtBag335
DirtBag335's Avatar
15
Drives: 07 Z4M
Not really, you hit 60 in 2nd and 3rd takes you past 100. It's as long as my 335 was but i think there a pretty good lentgh stock.
      09-20-2008, 08:20 AM   #6
tintboy
tintboy's Avatar
52
Drives: 2011 E92 M3
You are going to love it... I also got my 4.10s from diffs online. It was the best mod i did so far. 1st gear is still usable. I even had one of the members here meet up and take my car for a spin, and if i can get him to chime in he will say that the gears really bring the car to life.
Present 2022 M5 CS FROZEN BH
PAST~2011 E92M3 Space Grey Gintani STAGE X
      09-20-2008, 08:41 AM   #7
Starscream
Starscream's Avatar
Chimed
DO IT!
I'm going to look around for a set for my own car,
Imola Red Roadster
      09-20-2008, 08:43 PM   #8
Haretakis
Haretakis's Avatar
Drives: 2007 Silver Z4 M Coupe
I am considering this, but with the future possibly bringing and ESS supercharger to my car I would be scared that 1st would be utterly useless... Anyone with F/I e46 M3 and these gears??
ESS Tuning Software, JVT (Ebay) Headers, AFE Intake, RPI Scoop, ACS Pedals, and ZHP Shift Knob.
      09-20-2008, 09:46 PM   #9
MMMazing07
MMMazing07's Avatar
180
Drives: Z4M
if your going FI stick with the stock diff. traction would be a nightmare with 4.10s and a SC
      09-21-2008, 12:17 AM   #10
DirtBag335
DirtBag335's Avatar
15
Drives: 07 Z4M
I have read on the m3 forums of guys with a blower and 4.10's. They all said it is a very good setup to make smoke.
      09-21-2008, 02:48 AM   #11
epbrown
epbrown's Avatar
Not with our redline. Typically it seems most car makers try to set things up so you can hit 60 or 62mph (depending on market) while in 2nd gear. The stock 3.62 does that with room to spare, the 3.91 I've got puts you right at the edge, and the 4.10 is just outside it.
While I personally felt the 4.10 was too short for a daily driver, tons of M3 owners have already made the swap and have no complaints - I'm definitely in the minority. If I were going with them, I'd want to raise the redline a bit.
Attached is a comparison I did of specs for the Z4M with 3.91 compared to some other cars:
      09-21-2008, 07:42 AM   #12
Z FORE
Z FORE's Avatar
Drives: 2010 E93 Convertible
I have the Dinan package in my car, and Dinan recommends the 3.23 differential. Why would that be?
      09-21-2008, 08:14 AM   #13
epbrown
epbrown's Avatar
As I wrote above:
It's always about the 0-60 quote. You don't have an M, so your redline is a lot lower. Guess what speed you hit at redline in 2nd gear with your engine with a 3.23:1 final drive?
      09-21-2008, 02:24 PM   #14
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
I would not do gears with FI but some M3 owners have and said they like it. You can do software and have the redline increased for 4.10 if you want.
      09-21-2008, 03:20 PM   #15
AtoB
AtoB's Avatar
Drives: Z4M
what did the ring and pinion cost? and estimate on the install?
      09-23-2008, 07:31 AM   #16
Z FORE
Z FORE's Avatar
My car already redlines in 2nd at about 60 or 62. What would be the benefit of the 3.23 diff from Dinan or any other diff?
      09-23-2008, 10:51 AM   #17
DirtBag335
DirtBag335's Avatar
15
Drives: 07 Z4M
The ring and pinion shipped were just under a thousand. As for the install I am not sure yet. We were supposed to do it this weekend but my buddy was to busy to do it. It looks like it's going to cost between 500-900 for the install.
      10-22-2008, 10:19 AM   #18
Black///Mamba
Black///Mamba's Avatar
53
Drives: a beast
review?
      10-22-2008, 02:56 PM   #19
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
Decreasing the gearing (i.e., using a lower final drive gear) makes the car build revs quicker in all gears. When you build revs quicker you get to the max speed per gear faster. Of course the lower gear makes the theoretical max speed per gear a little lower, but other forces will keep the car from reaching those theoretical speeds, at least in top gear. In short, going from a 3.62 to a lower 3.91 gear for the Z4 M will increase acceleration measureably and there's little to no loss in actual terminal speed in top gear. Only downside is a slight increase in revs at a constant speed. The Z4 M has a fairly short gearbox, with the exception of 5th and 6th. Good enough to accelerate to 60 mph in under 5 seconds. The shorter final gear will put 0 to 60 times in the mid 4s range. Not bad. There are other mods which will also help acceleration without increasing whp/torque, such as a lighter flywheel/clutch set. Reason is the lower mass enables the engine to rev quicker. This alternative costs much less than the final gear swap. These are two mods I will do at some point. I prefer the gear swap first, especially while still under warranty.
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      10-22-2008, 03:17 PM   #20
epbrown
epbrown's Avatar
Here's a comparison chart I made after doing the 3.91 swap on my Z4M (left out the decimal on drag coefficeints). The Z4M is already a pretty good performance bargain, but the gears put you in some pretty exalted company in terms of acceleration, if not handling and top speed. I agree with MV about the flywheel, which seems really heavy in these, but I'll wait to do that when I have to go in for something else:
      10-22-2008, 03:58 PM   #21
Starscream
Starscream's Avatar
BTW for anyone interested these are now on sale at $775 shipped for 3.91 or 4.10 gears,
I'm very tempted at that price!
Imola Red Roadster
      10-22-2008, 07:32 PM   #22
killjohnnyforan
Drives: ///M Coupe
i bought these from DIRTYBAG, my diff is still being rebuilt as i am chaging out all the stock bearings as well as the crush bushing.
