      10-15-2018, 09:26 PM   #1
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Snapped Oil Drain Plug – DIY Repair
While removing my oil drain plug, the bolt snapped… most likely it was over-torqued or run in with an impact gun in the past.
Fortunately, the fix was simple. You’ll need:
1. EZ-Out or equivalent screw set. I bought mine from Pep Boys.
2. Small open-ended wrench sized to fit the end of your EZ-Out
3. Hammer
4. Drill (if your drain plug is solid)
5. Small magnet for debris
Insert the EZ-Out into the drain plug. I was lucky because my drain plug was hollow (likely aftermarket). If your drain plug is solid, you will need to drill out a small hole in the middle of the drain plug.
With light-medium force, tap the end of the EZ-Out with a hammer. It should only take one good tap.
Using your small open-ended wrench, turn the EZ-Out counter-clockwise. The damaged drain plug should start backing out.
Remove drain plug
Use your magnet to remove any debris. I had no debris because my drain plug was hollow. Had I needed to drill out the middle of the drain plug, I’m 50/50 on whether I would remove the oil pan to ensure no debris remained that could contaminate the oil. Besides being a big job, oil pans can leak once removed and reinstalled. Then again, oil contamination can destroy and engine.
      10-16-2018, 11:25 AM   #2
Reborn_
Drives: 2007 BMW Z4MC
Nice work. I would probably combine the magnet with flushing 10+ qts through the engine if drilling were required in lieu of dropping the oil pan.
      10-16-2018, 12:44 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Then replace it with one of these:
http://www.fumotousa.com/
      10-16-2018, 02:31 PM   #4
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
I got one of those snap off in my hand while trying to install one a few years back. Luckily I was able to use a flathead screwdriver to back out the broken piece. Been using the suction method on all my cars since. As funny as it sounds, having a dipstick was a requirement on my last car purchase, which ruled out most new BMWs
      10-16-2018, 02:53 PM   #5
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
i have one, it won't clear the bottom pan on my ride. never used it....
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      10-22-2018, 01:48 PM   #6
RossBMWZseries
This is really cool, first time I see car related GIF's............................
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      10-22-2018, 04:15 PM   #7
pokeybritches
2006 BMW Z4M  [8.50]
Haha, well I looked for a hosting service that would let me turn off auto-play. After a while the gifs hurt my head.
