View Poll Results: DKF section 1 kit - 100 or 300 cell CATs ?????
definitely 100 cell CAT 5 17.86%
definitely 300 cell CAT 14 50.00%
100 cell prefered but would consider 300 cell 5 17.86%
300 cell prefered but would consider 100 cell 4 14.29%
Voters: 28. You may not vote on this poll
      03-19-2013, 05:26 PM   #23
IDLE TIME
IDLE TIME's Avatar
Drives: still searching
Originally Posted by Finnegan
I don't have a horse in the race since I've got a total Euro setup. However, if I were in the market, I'd have to go for the 300 cell. I really can't see 100 cell passing smog in CA with a Euro header setup. I will say this would be a great option, since hacking up the stock cats isn't for everyone (and if not done correctly, is costly), and the Euro Cat solution is big $$$.
Of course, take my input with a grain of salt since again I'm not a potential buyer. I did not vote as I did not want to invalidate the poll.
Thank you for your input it is greatly appreciated perhaps it will help someone else make up their mind.
      03-19-2013, 08:47 PM   #24
bmwschnell
bmwschnell's Avatar
Drives: '07 Z4M coupe; '22 Ford Raptor
Don't forget, that if you drop the header CATS, you will still be running fewer total cells.
The two main things for me is minimizing rasp & running w/o CEL Light
Some don't mind the rasp sound , so 100 may be what they want.
I agree. I want the best of both worlds. I want to avoid a CEL on stock software. However, I want to get the most performance while doing so.
So here is my line of thinking. Our secondary cat is 200 count. Does anyone know what the count is for our stock headers? Is it also 200 count? If so, that means our cars come with a total of 400 count from the factory? So by running a 300 count cat, we aren't gaining that much performance.
I think the 200 count is the best compromise. Any thoughts?
      03-20-2013, 05:13 AM   #25
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Good question.
I'm not sure what cell count the OE header CATs are.
But where they are also creates more of a flow bottle neck than it would in a straight section.
These are also "hi flow" CATs.
I'm also not sure what that really means.
E.g. Does a "hi flow" 300 flow better than an OE 300???
      03-20-2013, 08:08 AM   #26
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
What I know about cats:
1. Metallic cats handle the heat of supercharger setups better than ceramic cats.
2. Precious heavy metal (platinum) inside the cat serves as the catalyst for the reaction. The more there is, the more pollutants are taken out of the exhaust (and the less likely it is you'll trip a CEL). There's no cheap way to add more platinum. In this sense, a 200 cell cat with 5x the amount of precious metals will flow and reduce emissions better than a standard 400 cell cat. But again, these precious metals are expensive!
3. The placement of the material inside the cat is important. In cheap cats, it is laid out like a rug and then rolled up. In high horsepower applications, this construction method suffers from the material telescoping, restricting exhaust flow- or even blowing out completely.
4. The cell count is only a cross sectional measurement. CPSI = cells per square inch. Obviously the length plays into how much restriction it poses in the exhaust.
In a nutshell, you get what you pay for. Cheap cats are just that - cheap. They work on stock Hondas, but not on high horsepower BMWs. I hated the price, but I went with HJS cats for my car's custom section 1. I'm sure DKF can chime in to let you know that the materials cost is unavoidable if you want quality. Unfortunately many owners say:
"Will this allow me to run headers without a CEL? Yes? I want it as cheap as possible!"
      03-20-2013, 09:45 AM   #27
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^great info, thanks
      03-21-2013, 07:07 AM   #28
IDLE TIME
IDLE TIME's Avatar
Very well stated and you are 100% correct. Congratulations on the HJS cats excellent mod. Cream of the crop cats !!! I agree there are many levels of cats. You are correct again metallic cats handle the heat much better than the ceramic cats. Once again you are right on target with the amount and placement of the precious material within the cat. We put a lot of research into our cats. My engineer is away in boot camp. (this would be a great time to have him here) I know our cats are a medium to upper grade cat. They are by no means a cheap cat. They were designed to work with our system as an independent component which relies on the other components to produce the exhaust flow we are achieving. How they would compare to HJS is really beyond my scope at this time ( That is why I pay my engineer lol) I do know according to my engineer our cats would give them a run for their money. My engineer developed this system for performance and cost in mind to our customers. I hope this helped with out confusing anyone. If more information is required let me know and I will attempt to answer your questions.
Last edited by IDLE TIME; 03-21-2013 at 12:05 PM.. Reason: oops found spelling error
      03-21-2013, 07:35 AM   #29
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for the update Doug.
Good to know you have a quality product CAT while still keeping the costs down for us.
      03-21-2013, 03:46 PM   #30
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Well said!
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      03-21-2013, 09:52 PM   #31
philjw
Drives: 2011 M3 Coupe
I'm definitely interested (see my thread debating headers and diff swap) but it would depend on the price, which is also holding me back on the euro cats. Everything's looking nice based on what I've read, but the only prices I've seen for the S-section and cat combo seemed kind of pricey... If I did it, I'd want the 300 count (and voted). Thanks to all working on this project.
      03-21-2013, 11:10 PM   #32
IDLE TIME
IDLE TIME's Avatar
We have been working hard to bring a quality product at a reasonable price. Prices are coming soon need to be sure everyone cases their vote. 100 or 300. Let us know.
      03-24-2013, 12:39 AM   #33
Jroc
Drives: Mcoupe
So having euro headers + this cat won't post any SES lights or need to reroute anything?
      03-24-2013, 11:31 AM   #34
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
This will be similar to using a euro section 1 but with better performance.
You will have to relocate the secondary O2 & EGT Sensors to this new section but it has the bungs already to go.
When it comes to SEL there are so many variables with our cars that it's impossible to guarantee but technically it should work just fine.
There is one of these 300 cell pipes that has run several thousand miles without a tune (tune added later) and no SEL .
      03-25-2013, 06:55 PM   #35
Jroc
Drives: Mcoupe
Sounds great!
      03-25-2013, 07:05 PM   #36
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Hey guys....
I have been talking to Doug at DKF.
Final production arrangements are in progress.
The GB for these will be up and running VERY soon.
This may very well be a one time production, so stay tuned & dont miss out.
Doug dropped a hint on prices and they are looking VERY GOOD
If you are considering this system & haven't voted in the pole, please do so.
Doug needs this information to determine how the production run will work out with his vendor!
      03-25-2013, 07:55 PM   #37
philjw
I'm still coming up to speed on all of this, but does anyone know about this setup from Fabspeed? http://www.vacmotorsports.com/catalo...-section-1.htm
Apparently not available yet but seems very similar but with hi-flow 200 cell cats? Any thoughts on how this might compare with DKF?
Also, it seems we don't know the cell count of the euro cat, correct?
      03-25-2013, 09:14 PM   #38
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Unknown when fabspeed will make theirs.
One big difference is the slip fit connection between S pipes & CATs, on the fabspeed.
The DKF has a much better race flange.
The DKF also has a flow engineered step pipe design in the S section.
....& the kicker will be the price ....just sayin
The target for the GB on the DKF is to have it up next week.
The GB will run for a month.
Originally Posted by avsbmw View Post
Just wanted to share my set up with you guys. I got one of the original test pipes from DKF and have been extremely happy. I have euro headers OEM xpipe (wanted to keep the raspy down) and el diablo mufflers. I also have the evolve tune. The S pipe is really good quality. The car has been running great with no CEL for several thousand miles.
Evolve tune added later....
      03-25-2013, 11:20 PM   #39
mousitch
Dark Sider
mousitch's Avatar
129
I know everyone will be ultra pleased next week...
      03-26-2013, 05:21 AM   #40
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
That's the target right now
Doug is currently wrapping up some final details.....
      03-26-2013, 04:46 PM   #41
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      03-28-2013, 05:36 PM   #42
IDLE TIME
IDLE TIME's Avatar
I have had a few calls on what does the DKF exhaust system weigh compared to to the OEM system I think beta did an excellent comparison so I thought I would repost it here
Bea well done excellent attention to detail and ease of understanding the results..
So it breaks down to:
Race mufflers 9.6 each, sport 11.2 each: 19.2 - 22.4
OEM is 22 lbs each: 44
-24.8 to -21.6
X-Pipe weighs 11 lbs.
Stock weighs 15 lbs
- 4
s-pipe (9lbs) + 100 cell cats (7lbs): 16 lbs
stock US is 19 lbs
- 3
Adding that all together we get 28.6 to 31.8 lbs weight savings.
Thank you again sir WELL DONE!!!!!
      03-29-2013, 10:11 AM   #43
gmd2003
gmd2003's Avatar
352
-24.8 to -21.6
Stock weighs 15 lbs
- 4
stock US is 19 lbs
- 3
Thanks for the putting the weights on this thread! It was good speaking with you yesterday.
      03-29-2013, 12:01 PM   #44
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
-24.8 to -21.6
Stock weighs 15 lbs
- 4
stock US is 19 lbs
- 3
I suspect the Headers, Euro or other most are adding or have eliminating the cats reduces weight too!
