04-01-2012, 03:12 PM | #1 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Track setup
Thinking of using stock 18 inch wheels along with fresh tires as a dedicated track set.
What sizes have you guys tried? |
04-01-2012, 04:28 PM | #2 |
Rep 666
For the track I'm running E46 M3 18" wheels with Toyo R-888 tires 245/40-18 front and 255/35-18 rear. 10mm spacers up front to clear the TC Kline coil over struts. 3.5 degrees negative camber in the front and 2.0 degrees negative in the rear
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
04-01-2012, 05:04 PM | #3 | |
Rep 12,565
I like Stat Specs a lot, can drive to track with them and perform exceptionally well in the wet (my past few events actually got hit with random showers). For a little less you can go Hankook R-S3. GRM did a review few month back saying they were the best street tire for track duty but their wet performance isn't as good as the SS and they don't last as long neither but for the price difference it's definitely worth considering imo. |
09-19-2012, 02:24 PM | #4 |
Rep 59
@DSC_OFF
You are running a square setup on 17's right ? With coilovers iirc. What widths wheel/tire are you running ? Would spacers be required on stock strut /spring ? Any other clearance issues ? Recommended camber plates ? If swapping back to oem staggered setup for non track, how bad does the negative camber effect things ? tire wear and handling. Any more info you can share ? I'm trying to piece together a setup for track days ( that I can drive out there ), and the idea of a square 17 setup sounds appealing. Still stock suspension for now. Thanks. |
09-20-2012, 01:29 PM | #6 |
Rep 2,650
For stock wheels we would recommend 235/40/18 front tires and 265/35/18 rear tires. These are one size up from the stock sizing but will offer better grip and will fit without problems. To go any wider in the front you will need negative camber achieved through camber plates. Like others have mentioned Dunlop Star Specs are a great track/street tire with really good wet and dry performance. The Hankook RS3 has a little bit better dry performance, especially when the weather is really hot, but suffers when there are wet conditions.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
