02-27-2012, 10:05 AM | #23 |
Rep 1,855
I would definitely consider buying a good looking, functional, somewhat easily installed rear diffuser made out of high temperature plastic, under 400 bucks.
02-27-2012, 11:18 AM | #25 |
Rep 5,328
id like to see an alloy coolant header tank with sight glass and Temperature reading coolant cap :-) would be nice if we could get alittle more capacity out of it as well, the plastic unit does not fill me with confidence especially when you hammer it all day on the track and it starts to look like its going to blow up!!! lol
02-27-2012, 01:04 PM | #26 | |
40
Rep 1,481
Yes. The plugs are done and the mold is almost done for them. They are a direct bolt-in replacement from the stock plastic units....just in CF and visible weave. |
02-27-2012, 01:17 PM | #27 |
Rep 5,328
im in!!!
02-27-2012, 01:30 PM | #28 |
Rep 1,603
Drives: Imola Red Z4MC
yes but i'd like the same wind-tunnel proven results with a more aggressive look!
///M - Some Mods 'N Stuff
02-27-2012, 01:36 PM | #29 |
Rep 4,531
02-27-2012, 02:40 PM | #30 |
Rep 556
Drives: 2003 ESS TS1 Z4
Models in, on and around the cars NOT in platform high heals!
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
02-27-2012, 03:34 PM | #31 |
instagram 997turbotom
279
Rep 7,377
I think the ac shnitzer one looks amazing, but wind tunnel testing is $$$$$
03-07-2012, 12:36 PM | #32 |
Rep 296
I would like to see a valve shim set released that has half steps of .02mm in it. Depending on a particular engine the closest you can get some valves is .03mm of gap while others are perfect with .01mm gap. Ok so even .03 is within spec for these engines but if you are working every possible angle of performace there is a gap here, pun intended.
03-07-2012, 02:11 PM | #33 | |
Rep 784
Drives: 2011.5 E90 M3
03-07-2012, 02:28 PM | #34 |
MPOWERD
15
Rep 338
Drives: 2010 M6
2010 Dinan M6 Coupe--2006 Z4MC--1994 E36/M3 Track Prepped
BMWCCA #442445 YouTube Channel: http://www.youtube.com/user/Randy23185 |
03-07-2012, 02:56 PM | #35 |
Rep 296
It would be relative to your performance additions.
Your cam would come in sooner with a greater peak lift. Granted it is not by much each valve .02mm but at .04mm per cylinder or .24mm over 6 cylinders in adds up pretty quick then. With both intake and exhaust valves ~.48mm volume throughput overall that you would be gaining. Not to mention minor tweaking of timing etc that would result. So why would you not want your 5hp on a stock motor? That will be a much greater number on a stage 1 or 2 car that has some real volume to move. Not to mention that it is really easy to do a valve job. People out there port heads right? Just to get some flow improvements without increasing volume and they are gaining power. How about port matching exhaust/intake manifolds? If every little bit adds power here is a little bit more we can gain with just a tiny spacer. Or how about a crazy senario, You have the new stage 3 ESS kit and you are making 620rwhp, that is 103hp per cylinder. Say you have one cylinder both valves min spec .02mm and 1 cylinder max spec both valves .10mm. You are self tuning your kit trying to tweak everything you can get out of it and you are still using the two sensor wide band 02 system so it is working off averages for your fuel map, timing etc so know how much power is that costing you for that lax cylinder? Theoretically that could be the differance of dropping a cylinder due to a lean or other adverse condition. |
03-07-2012, 07:07 PM | #36 | |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
I've had it on for 2 days and so far I've been getting ground clearance issues.
03-07-2012, 09:09 PM | #38 | |
Rep 202
Z4 M coupe with Super Sprint exhaust and X pipe, RPI Scoop, AFE air intake, ESS tune, DINAN 4.10 Limited Slip Differential, OEM CF spoiler.
M3 E92 Coupe with DCT, Akrapovic Evolution exhaust, ESS tune, DINAN 3.62 Limited Slip Differential, OEM CF performance parts. 1M Coupe... Loving it |
03-07-2012, 10:12 PM | #39 |
Rep 855
I would be interested in a set of direct bolt on Z4M upgraded sway bars. Also FCAB's and other bushings. I also personally would like it if somebody make a set of neoprene engine mounts since i would like something between rubber and poly
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
03-07-2012, 10:22 PM | #40 |
Rep 1,603
@L4zy,
Thats the kind of look I want! With those aggressive fins in the middle! The AC one is sick but lacking the fins!
03-07-2012, 10:42 PM | #41 |
Rep 879
Maybe front canards.
I used to have the Bimmerworld canards on my E46 M3, it was expensive for the quality you got... But it was a nice upgrade with the splitter. |
03-07-2012, 10:56 PM | #42 |
Rep 208
Does anyone make an aluminum front underpanel for Z4 M? I always thought I'd get the JT-Designs underpanel when I had my E36, but never got around to it. In the mean time, I'll see if autocross cones are friendlier to Z4 M plastic.
03-08-2012, 09:21 AM | #43 | |
279
Rep 7,377
03-08-2012, 09:23 AM | #44 | ||
279
Rep 7,377
