      08-01-2011, 08:52 AM   #45
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
i had to make my own egt bung i look and found nothing for it . i made it from a pressure washer gun tip same thred and all i just cut down to size.
you can most likey go to a pluming store they will have the pipe with thred
euro headers <> gruppe m <> ac schitzer strut bar <> arqray mfflers <>
      08-01-2011, 09:08 AM   #46
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
Originally Posted by txz4 View Post
all of this info is great! i plan on doing my headers in the next few weeks so i will be watching this thread to see what people come up with! i intend to just mark everything and insert just as it was pulled out. i think that those bungs that were posted should help to clear up the cel issue, as long as they are mounted far enough back, as it keeps the o2s raised up out of the flow to a certain extent.
To clarify, i will need:
Turner header swap kit (gaskets etc)
2 of those 02 bungs
anyone know of the best places to order both of these items? and what is the solution for relocating the egt. Did y'all just remove the one from your current headers or is there another solution.
you need to mark everything in banks..... bank 1 sensor 1, bank 2 sensor 1 , bank 1 sensor 2 , bank 2 sensor 2 ........cylinders 1 2 3 is bank 1 , cylinders 4 5 6 is bank 2 , so that means the header at the front is bank 1 and the header at the back is bank 2 ..
      08-01-2011, 09:52 AM   #47
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I was looking for this info, thx
      08-01-2011, 11:26 AM   #48
txz4
txz4's Avatar
59
Drives: 2006 M coupe
good info so far!
      08-01-2011, 01:14 PM   #49
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Jack at custom performance usually stocks EGT bungs.
http://www.custom-performance.net/pr...rt/pc/home.asp
      08-01-2011, 02:21 PM   #50
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Found this thread on the EGT bung
Looks like they're saying that 1/8 NPT is equal to the M14 x 1.5 OE
      08-02-2011, 07:20 PM   #51
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
...found an M14 x 1.5 fitting for the EGT at a local hydraulic repair shop.
      08-02-2011, 09:42 PM   #52
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
thats great take pic and let us know how it goes know that you have all you need .....
      08-03-2011, 07:35 AM   #53
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Looks like this.
......I'm just going to cut the back fitting off & weld it at the nut.
      08-04-2011, 10:52 AM   #54
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
700 miles on after the mod and NO light .....
      08-04-2011, 12:29 PM   #55
txz4
txz4's Avatar
59
Looks like this.
please let us know if this works, and if you can get a part number or source for others that would be awesome!
