07-10-2011, 06:03 PM | #1 |
Rep 132
euro headers w/ relocated o2 & egt
so i got my headers from a member a couple weeks ago...befor i installed then i sent to jet hot for ceramic coating extreme sterling. it took six days to get them back i think that was fast.
made holes for o2s and egt , welded then on myself . i dont have much experience welding but i got the job done..[ATTACH][ATTACH][/ATTACH][/ATTACH] so now about the wiering i just unfoled it from the valve cover and a bit from the harness ran it down the transmission tunnel and the on top of heat sheilds . looks o.e. very clean . the heat sheild in the back had two holes so i ran the o2 wiering on top of it .[ATTACH][/ATTACH] well now the good stuff , driven the car for about 400 miles and NO CODES 1 the power gains is amazing no more bog , lag , fast fast fast 2 more sound powerful deep bit raspy , pops , blerps 3 love it , loveit
euro headers <> gruppe m <> ac schitzer strut bar <> arqray mfflers <>
07-12-2011, 12:41 PM | #3 |
Rep 987
Cool. I have some euro headers just sitting around. Been thinking of doing this same thing. Update this thread after more miles or if you get any codes! Are you able to check if all the readiness codes are completed?
07-12-2011, 02:45 PM | #4 | |
Rep 132
yes, i plan on puting more miles on it this week and i already check the monitors and all are set to ready no codes . went on the highway sunday night got it up to 110 mph and still no codes just get better....
07-12-2011, 02:52 PM | #5 |
Rep 11,667
Do you have a header tune? (eg ESS)
07-12-2011, 04:55 PM | #6 |
Rep 132
no tune, and no program of anykind just stock ..
07-12-2011, 08:14 PM | #7 |
Rep 1,739
Drives: 2008 Z4MC
Do u have any pics of your O2's mounted on Sec 1 (more detailed than above)?
07-13-2011, 08:44 AM | #8 | |
Rep 132
not now , but next week i will be putting back on my o.e. x-pipe to see if a bit of rasp goes away . i will take some pics then of the o2s ...
07-18-2011, 01:12 PM | #9 |
Rep 132
500 miles on the car and NO light , i'm putting back the o.e. x pipe to see if the rasp comes down a bit .....here some pics of the cat....
07-18-2011, 02:55 PM | #11 |
Rep 132
07-19-2011, 02:44 PM | #16 |
Rep 11,667
...so same bungs in the same location?
From these pics it looks like they are welded at the base of lower bung nut. Are yours welded in the same way? I'm just trying to establish if there is a pattern here. Maybe our systems are finicky to bung design & location. Also; I assume you guys cut off the threaded portion rather than inserting it into the exhaust pipe?
07-20-2011, 10:45 AM | #17 |
Rep 132
^ I did not cut off the threaded portion , but if i had to do it again i would not use the lower bung nut just make the hole and weld it to the pipe.....
07-20-2011, 11:06 AM | #18 |
Rep 132
IMO the o.e. x-pipe sounds soooo much better with the headers , the re x-pipe was too raspy at high r.p.m.s
07-20-2011, 11:16 AM | #19 |
Rep 11,667
You only had rasp at he top end?
That's interesting. I was thinking about doing the same thing. Since I have the R.Eng on now, I'll probably experiment with both.
07-20-2011, 11:28 AM | #20 |
Rep 132
only at top end , and when cold . when it got warmed up low idle was fine to me it was not a nice sound , now with the o.e. x pipe it feels like i have more torque off the line.... huh ?
07-20-2011, 01:09 PM | #21 |
Rep 1,739
Drives: 2008 Z4MC
Interesting about the bungs, and interesting about the OE X-pipe.
I'm really torn between keeping my SS - X pipe on or not. I think headers, SS-X, and Remus cans would be a nice complete system. I suppose I'll try both and see what happens. My last chance of getting rid of my CEL will be to move my bungs approx 1.5 inches and see what happens. I can't believe it would make a difference or that the O2's are so sensitive that it'd change anything |
07-20-2011, 01:35 PM | #22 | |
Rep 11,667
I can't figure if it's just that our cars are hit & miss no matter what you do. OR Is there a particular bung install that works consistently. Those J bungs that you got are what I was originally planning to go with. Now, I'm not sure what to do. A couple of related things I'm looking at. 1. Are the CATs loosing too much heat by opening up the surround shields too much. 2. try to pass as much heat as possible down to the CATs by coating the headers. - I'm planning to do this XMC coating, which was primarily developed for the diesel industry but is now being used for other applications. It is a dual coat system that coats inside & outside of headers.
