      01-05-2021, 10:57 AM   #1
KLEETIS
Drives: 2008 BMW Z4si Sport Package
Help Tire Size Change 2008 Z4si
I'm looking to change tire size on my 08 Z4si factory stock wheels it has the Sport package 18" wheels I beleive the factory lowers the suspension on this model.
1- Does anybody know the width in inches Front 18x8" is correct?
2-Rear 18x9" is correct?
Important for me without changing or adjusting anything front or rear will I run into any problems?
1-I want to change the front from 225/40R 18 to 235/40R 18 is there any rubbing concerns?
2-I want to change the rear from 255/35R 18 to 265/35R 18 also is the there any rubbing concerns? and is the rear wheel at least 9" wide tire company wants this for a 265/35R 18 tire?
Using a tire caculator there is not much difference is height width. Has anyone done this on the same car? Thank You for you time!
One last thing I was going to go to regular tires and carry a plug kit.
Anyone more happy with regular tires over run flats?
I know it sounds simple and they should fit just want to be sure. This is my second BMW first was a 98 Z3M silver should have kept it!
      03-02-2021, 09:19 AM   #2
KLEETIS
About ready to delete this. Somebody must know if they will rub or not?:
      03-02-2021, 10:19 AM   #3
Steeler
Steeler's Avatar
2429
I ran 265/35/18 on et 35 18x9.5 and 235/40/18 on et 35 18x8.5 with slight rubbing on the rears.
Lowered 1" all around.
Run flats ride harsh. No concerns with conventional tires. Carry a plug kit if you drive where you may pick up a puncture.
Your results may vary.
      04-01-2021, 10:16 AM   #4
Roadroach
Roadroach's Avatar
165
Drives: 2006 Z4 3.0si coupe w/stick
The 18" rims on the sport package are 18x8 in the front and 18x8.5 in the rear.
bmwstylewheels.com is a good resource for specs on all bmw wheels (they list sizes/offsets and weights for nearly all bmw wheels).
My understanding is that 255 is about as wide as you can go on the stock 8.5" rear rim.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list)
2015 335i GT
2014 981 Cayman S manual
