      08-01-2015, 09:28 PM   #177
Gary07110
Gary07110's Avatar
Drives: 2008 Titanium Z4 3.0si Roadste
New VMR 810's. Love the wheel but the ride is shit! Not sure what is going on. Got a vibration in my wheel, troubleshooting is getting me nowhere.
      08-02-2015, 03:52 PM   #178
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
What troubleshooting have you done?
It usually comes down to hub centric issues or balancing.
It would be best to start a new thread on your issue for more help with it
      08-06-2015, 10:15 AM   #179
MeisterS
Rennfahrer
MeisterS's Avatar
47
Drives: E90 325xi E36 M3 & E92 M3
Had the same issue when I switched from 19" to 18" set up. Road -force balancing solved the issue for me.
Current- Jerez Black E92 M3 | Arctic Silver E36 M3/4/5 | Monaco Blue E90 325xi
Past- AW Z4-M roadster| JB Z4-3.0si | '98 Accord V6 coupe
      11-22-2015, 04:37 PM   #180
m3power13
m3power13's Avatar
111
Drives: E92 M3 Stripper
Originally Posted by mpm3 View Post
just in ! 18x9.5 245/40r18 275/35r18 18x10 arc-8
suspension is kw v3
This looks really good. I'm so torn between this setup or OEM CSLs......
E92 M3 - Alpine White - Carbon Roof - 6 SPD - Speed Cloth - No NAV/EDC - Meisterschaft - Signature Forged
      12-29-2015, 09:52 PM   #181
michaelyang601
michaelyang601's Avatar
Drives: STI Cayman S Black Edition Z4M
Volk Rays Progressiv Me painted in black. 18x8.5 et42 front, 18x9.5 et30 rear wrapped in Michelin Pilot Super Sport 235/40/18 front, 265/35/18 rear.
      03-13-2016, 12:31 AM   #182
doane2u
Drives: 2012 135i M Sport E88
Thumbs up
Not very exotic.. stock OEM wheels on my '07 3.01, but I like them. I still have to do some work on repairing some pretty severe curb rash the former owner did, but the other day I painted the calipers, nuts and valves... and the lower front air dam/bumper and grill spliter and I like the results. The whole bottom dam/bumper was really scared up and nicked up, so I prepped, primed and painted the whole lower part and decided to add the red "tongue" accent. I kind of like it. I also blacked out the chrome kidney rings.
      03-13-2016, 05:26 AM   #183
michaelw66
michaelw66's Avatar
Drives: Z4
My Z4 on 20's
Here is my Z4 on 20's with 245/30/20 on ft and 275/30/20 on back.
      03-14-2016, 08:06 AM   #184
VossenCoupe
Drives: Z4 M Coupe
I am not the only one with 20" now
      03-14-2016, 08:15 AM   #185
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Now you need a BBK to fill up all that empty space.
      03-25-2016, 02:55 PM   #186
Exist
Drives: 2007 Z4 3.0si Coupe
18" VMR V710's
-Spencer
      05-15-2017, 09:10 AM   #187
03z4
Drives: 2003 z4 2.5
Anyone run 18x9.5 et 35 front and 18x10.5 et 22 rears?
      05-15-2017, 09:26 AM   #188
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
this page should be able to answer your questions, though i see you're not in an ///m. i highly doubt that rear size will fit without substantial modification to the car.
      05-15-2017, 10:59 AM   #189
doane2u
My E85 2007 OEM style 200 wheels newly powder coated... I really like the looks of these with my Jet Black exterior and it was a lot cheaper then buying new aftermarket wheels.
      05-15-2017, 01:19 PM   #190
03z4
Drives: 2003 z4 2.5
Thanks...
Tire matching questions...
I have 255 35r 18 on a 9.5 wheel...what would closest match be for an 8.5" wide wheel? Would 225 35r 18 match?
      05-15-2017, 09:55 PM   #191
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
I had completely forgotten about this thread. Got these BBS CI-R on the car for about 6 months now. Really liking the Platinum Silver - Still on the light side, but just dark enough to hide some brake dusts
Vanne1620.50
Pyrat 21417.50
      05-16-2017, 02:47 PM   #192
doane2u
XMetal: Those look really good on your red car, how much were they?
      05-16-2017, 03:17 PM   #193
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wheels were roughly $2,500 from TireRack
      05-16-2017, 08:20 PM   #194
03z4
Drives: 2003 z4 2.5
Those look great on your car...that wheel had always appealed to me because they look larger than other wheels the same size due to the spoke design.
XMetal1131.00
      05-17-2017, 02:48 PM   #195
03z4
Drives: 2003 z4 2.5
I ran 18x8.5 fronts with 225 40 18 and 18x9.5 rears with 265 35 18 for the past 2 years...recently I had to order new tires due to excessive inner wear after both rear springs broke. I moved down to 225 35 front and 255 35 rear. Eventually I'll probably lower it and this reduced tire size should ease that ride height change.
      05-17-2017, 05:39 PM   #196
3002 tii
3002 tii's Avatar
2282
Why do you run a taller rear tire?
Follow for latest mods
      05-17-2017, 08:09 PM   #197
03z4
Drives: 2003 z4 2.5
When I originally picked out my wheel setup someone on this or another z4 board stated that this size combo worked out be be the closest match for final resulting size between 8.5 and 9.5 wheels. Was actually the front that was "taller" being the 40 series. But to be honest the combo was a very good match visually you could not tell a difference.
      05-17-2017, 10:53 PM   #198
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
I believed what "3002tii" meant was your new tires will be:
Front sidewall height: 225mm x 35% = 78.75mm
Rear sidewall height: 255mm x 35% = 89.25mm
So the rears on your new setup WILL be "taller" than the fronts
Your previous setup are actually much closer matched with the rears just slightly more "taller":
Front sidewall height: 225mm x 40% = 90.00mm
Rear sidewall height: 265mm x 35% = 92.75mm
