      04-18-2015, 09:27 PM   #1
itdnwiwbp
Drives: 330iZHP
CPV Question
Hey guys. I'm gonna be starting my Euro header and cat conversion tomorrow and I have a Rogue CPV o-ring to install while I've got things apart. So, stupid question but I just want to be sure from someone who has done this to avoid making a mess. Does the oil need to be drained before removing the valve? From what I've read it doesn't sound like it - just a couple drops, not a flood when removed - but, as I said, I just want to be sure. Thanks!
      04-19-2015, 09:08 AM   #2
mtnbkr
mtnbkr's Avatar
Drives: '06 IB Z4MC
No need to drain. At most you might get a dribble of oil, easily cleaned up with a rag.
I did mine recently but it's still leaking (replaced with upgraded o-rings). I think I'll have to use thread sealant this time around to be sure.
Good luck.
      04-19-2015, 10:10 AM   #3
itdnwiwbp
Drives: 330iZHP
Thanks for confirming that. What type of thread sealant are you going to use? You didn't replace the valve, just the o-ring right?
      04-19-2015, 05:20 PM   #4
mtnbkr
mtnbkr's Avatar
Drives: '06 IB Z4MC
Yes just the o-ring.
I had a a leak coming from the large oil pan plug on the driver's side and used this on the threads:
http://www.permatex.com/products-2/p...sealant-detail
I have some left over so that's what I'll probably use.
      04-19-2015, 08:14 PM   #5
itdnwiwbp
Drives: 330iZHP
Cool. Thanks a lot for the advice!
      04-19-2015, 10:43 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
There's an oil port above the threads.
I don't think thread seal is going to help.
Make sure the O-ring is intact and everything is nice and clean where it seats.
      04-20-2015, 12:56 AM   #7
itdnwiwbp
Drives: 330iZHP
Ah, good to know. Thanks for pointing that out.
      04-20-2015, 02:17 PM   #8
mtnbkr
mtnbkr's Avatar
Drives: '06 IB Z4MC
good call, I seriously hope the extra o-ring I got will fix this for good.
